Is My spec ok?
Isthised
PCS SPECTRUM RGB MID TOWER CASE
AMD Ryzen 7 3700X Eight Core CPU (3.6GHz-4.4GHz/36MB CACHE/AM4)
ASUS® ROG STRIX B450-F GAMING (DDR4, USB 3.1, 6Gb/s) - RGB Ready!
STANDARD AMD CPU COOLER
NO RECOVERY MEDIA REQUIRED
Welcome Book
Logo Branding
PCSpecialist Logo
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am4-gen3-pc/mdXHsUFDAN/
aimed for gaming at 1080p / 1440p, room for future upgrades would be nice, thanks in advance
Steveyg
Yeah there are quite a few glaring issues mate, it's seems you've compromised everywhere to go for a premium GPU which is pretty much the opposite of what we would advise. Previous Gen CPU, previous gen Motherboard, PSU that's extremely light, odd storage set up and a very basic case. Then a really overpowered GPU to completely unbalance the build, sorry to be blunt mate but it's how I read it
Can you let me know your budget, what monitor you'll be using what the machine will be used for and we can help you get something that will suit your needs much better and last you a long time?
Isthised
No need to apologize, I needed the advice, my budget is around 1.5k to 2k
looking to play games mostly, some demanding some not, (sorry if that's not very helpful)
and I'm currently using a 1444hz 1080p monitor but I'm looking to upgrade to a 1440p one fairly soon
Ok based on the idea of 1440p in the near future this is where I'd go, also assuming you've got access to legit version of W10 as you've specified no OS
1TB CORSAIR MP400 NVMe PCIe M.2 SSD (up to 3480 MB/R, 1880 MB/W)
Corsair H100i ELITE CAPELLIX RGB Hydro Series High Performance CPU Cooler
Price: £1,990.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am4-gen3-pc/4VVG5a!wPS/
Steveyg
Hi Martin,
Is there a reason for the B550 STRIXX as opposed to the TUF X570? X570 comes with PCie 4.0 which I don't believe the B550 STRIXX does? Other than that this is a very solid build for top end of 1440p
sck451
B550 has the CPU lanes at gen 4 speeds (which means the 16x slot and the first M.2 slot) and the chipset lanes at gen 3 speeds. Unless you want two gen 4 M.2s, the B550 is fine. (I went for the X570 because I want to do precisely that at some point, but it's kind of unnecessary...)
Steveyg
For a build closer to the £1500 mark there is this option as well, although considerably less powerful than Martins build.
I would ask if your comfortable installing Windows as well? It's quite time consuming with a lot of drivers to install, I almost always opt to have it done for me for convenience, but hey if you know how to do it and don't mind I can get why you would want to save there
Price: £1,686.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am4-gen3-pc/Z8QE7TpWdY/
Isthised
Also, does anyone know approximately how long the wait time for the 3070 is at the moment? its fine if its just a rough guess
Isthised
In this spec, which I'm going to use for gaming at 1080p and later 1440p, is it better to go with the 5 5600x or the 7 5800x, bearing in mind that the 5800x is significantly more expensive for a fairly small boost to fps? I'm not that concerned with the budget but I also don't want to pay significantly more for an insignificant difference. Thanks
Welcome Book
Logo Branding
PCSpecialist Logo
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am4-gen3-pc/eAJfzWKWaP/
Steveyg
Welcome Book
Logo Branding
PCSpecialist Logo
The 5800X is a massive upgrade from the 5600X where the cost will come in is the upgraded motherboard and CPU cooling that's also needed. Plus you'll need a case that can generate good airflow as the 5800X runs very very hot. I'll put together a 5800X build here shortly with a 1440p GPU to give you an idea of costs
Steveyg
This is what you'd be looking at for a 5800X 1440p build. There are saving that can be made here though
CORSAIR 5000D AIRFLOW TEMPERED GLASS GAMING CASE
Corsair H150i ELITE CAPELLIX RGB Hydro Series High Performance CPU Cooler
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am4-gen3-pc/HSSNd6Fv9a/
Isthised
Cheers again, but would you mind just explaining how the 5800x is such a massive upgrade? I watched a lot of benchmark videos and they tend to draw in relatively similar FPS counts.
Also, I just realized it posted my un-amended spec, but it won't let me post my amended spec to forums properly but ill put it here:
- CORSAIR 4000D AIRFLOW TEMPERED GLASS GAMING CASE
- AMD Ryzen 5 5600X Six Core CPU (3.7GHz-4.6GHz/35MB CACHE/AM4)
- ASUS® TUF GAMING B550-PLUS (DDR4, USB 3.2, 6Gb/s) - ARGB Ready!
- 16GB Corsair VENGEANCE DDR4 3600MHz (2 x 8GB)
- 8GB NVIDIA GEFORCE RTX 3070 - HDMI, DP
- 500GB SAMSUNG 980 PRO M.2, PCIe NVMe (up to 6900MB/R, 5000MB/W)
2nd M.2 SSD Drive
- 1TB PCS PCIe M.2 SSD (2000 MB/R, 1100 MB/W)
- CORSAIR 850W RM SERIES™ MODULAR 80 PLUS® GOLD, ULTRA QUIET
-CoolerMaster MasterLiquid Lite 240 High-Performance Liquid Cooler
sorry for terrible formatting but the website is being funny about posting my amended spec for some reason
Games r moving towards using 8 cores ps5 and new xbox have 8 core cpus newer triple A titles will more then likely use 8 cores metro enhanced edition with ray tracing is you guessed it 8 cores the 5600x will do but if you want ultra presets for future games you will want the 5800x
NoddyPirate
Grand Master
I think while many current titles may not fully utilise multiple CPU cores - and therefore the 5600X will run very close to the 5800X right now - things do seem to be changing rapidly. The 5800X would be a great future proofing bet against that trend I would say?
Isthised
ok, thanks all, I think ill go for the 5800x, largely because I very rarely upgrade my PC (5+ years) so it seems like solid future-proofing.
Again thanks for the great advice
