Androcles
Rising Star
Hi guys, i'd appreciate a bit of advice on an issue i'm having with my PCSpecialist PC, I think the HDD boot sectors are shot but i'm not sure, here's what's happened.
I switched it on last night and it loaded up to the Win10 login page fine, before logging in I had some tidying up to do so I left it, when I came back it was just in time to see a message about a device failed and then went to a blue screen and rebooted.
When it rebooted it loaded up the Win10 startup repair tool and did it's thing, then rebooted again. It then loaded up into a screen with there option boxes (cancel and run windows 10, advanced tools and shut down), clicking cancel and run windows just reboots the PC and loads back to the same screen again ad-infinitum, shutdown of course works, and the advanced option loads a screen with all the repair and restore tools.
I've tried all the repair and restore options and none of them have made any difference, I just keeps booting into the windows repair software.
I've done a few minor troubleshooting tasks as follows:
1. Checked the connections on the HDD: all fine.
2. Checked in UEFI/Bios to see if the HDD is missing: On the basic screen there's that nifty little drag and drop utility for boot devices, it doesn't show in there.
3. Pressed the F key for boot options while booting: The HDD shows in that list and when it is chosen will load into Windows 10 with no issues at all.
This leads me to think there may be an issue with the boot sectors of the disk which identifies it as a bootable drive, but i'm not sure. Is anyone able to advise me further and if it is an issue with sectors on the drive is there a way I can fix it? Would reformat/install work?
My Specs are:
InWIN GT1 BLACK GAMING CASE
Processor (CPU): Intel® Core™i5 Quad Core Processor i5-4670 (3.4GHz) 6MB Cache
Motherboard: ASUS® Z87M-PLUS: m-ATX, USB3.0, SATA 6.0, XFIRE
Memory (RAM): 16GB KINGSTON HYPER-X GENESIS DUAL-DDR3 1600MHz, X.M.P (2 x 8GB KIT)
Graphics Card: ASUS® NVidia GTX960 Stryx 2Gb
Hard Disk: 500GB 3.5" SATA-III 6GB/s HDD 7200RPM 16MB CACHE
Second Hard Disk: 1Tb Seagate Barracuda
DVD/BLU-RAY Drive: 24x DUAL LAYER DVD WRITER ±R/±RW/RAM
Power Supply: 450W Quiet 80 PLUS Dual Rail PSU + 120mm Case Fan
Processor Cooling: Super Quiet 22dBA Triple Copper Heatpipe Intel CPU Cooler
My Specs are:
