Is it safe to lay gaming pc on its side??
OneZeoN
Hi
I'll soon be getting a new gaming rig with the CORSAIR CRYSTAL SERIES 570X RGB GAMING CASE
it's going to be used in the living room and I've been wondering is it safe/ok to lay a pc on its side these days?
It would look a lot better in my set up laying horizontally but if it's not safe I'll find another solution.
Sides of case is tempered glass and not blocking vents etc
Specs below....
AMD Ryzen 7 2700X Eight Core CPU (3.7GHz-4.35GHz/20MB CACHE/AM4)
Gigabyte X470 AORUS Ultra Gaming: ATX, USB 3.1, SATA 6GBs - RGB Ready
8GB NVIDIA GEFORCE RTX 2080 - HDMI, 3x DP GeForce - RTX VR Ready!
1TB SEAGATE BARRACUDA SATA-III 3.5" HDD, 6GB/s, 7200RPM, 32MB CACHE
500GB SAMSUNG 970 EVO M.2, PCIe NVMe (up to 3400MB/R, 2300MB/W)
Corsair H100x Hydro Cooler with RGB fans
steaky360
I don't think it will cause an issue, just don't put it on its side when its turned on :)
That case is certainly designed to be upright though, but as long as you're not blocking anything, I can't see what the problem would be, ultimately the PC won't know what orientation its in!
OneZeoN
Cheers both
Yeah went with the Corsair case in the end as if it runs ok horizontally then it could be on view a lot so wanted it to look semi non garish lol
