Hello everyone,
as the tittle says, I'm interested in adjusting the fan speeds on my skyfire laptop.
The reason for this is that the GPU gets a bit hot while gaming (around 80-85 ºC), but the fan will only be working at about 40% capacity. I then hit the "fan boost" button, which puts the fan at 100%. That solves the problem quickly (to around 70ºC), but then when I turn it off I get hight temps again, and so on...
I would like to be able to tweak the fan speed so that I never get high temps, but not having to have the fan at 100% at all times. Hope I explained myself well enough.
PS.: I tried MSI afterburner and EVGA but they only control GPU fans, not the laptop fan. Also tried to use Speedfan, but it kept crashing the pc.
Thank you!
Thank you!
