I was wondering whether it would be possible to upgrade a 2 year old P150EM from a 675MX to a 980M. Do they use the same socket, dimensions and generic heatsink and are they even possible to buy on their own.
I believe it is possible to replace the GPU but I don't think you can get the 980m. I pretty much doubt there is a bios upgrade available that allows you to fit the 980m and it will be quite difficult to find a mobile gpu that is compatible with chassi. For an official response you may want to contact PCS directly
