is 6990m worth the upgrade for gaming?
ryafre496
above question really.
some people say gt580m others say 6990m. the price is the biggest thing.
is the 6990m can and will run anything high settings?
cheers
Music Guy123
The 6990m is a very good card, especially for the price. However,it isn't quite as good as the 580m and it doesn't have as good driver support. It also runs slightly hotter. Your choice though, if you can afford it, the 580m would be the best, if not, the 6990m will be fine.
  • Like
Reactions: PCS
AndyL
The advantages and disadvantages of each card are as follows:
GTX580M - Advantages
1. Good driver Support.
2. Most Powerfull Mobile GPU available.
3. Runs quite cool compared to AMD cards.
4. CUDA support.
GTX580M - Disadvantages
1. Expensive!
AMD 6990M - Advantages
1. Almost as powerfull as GTX580M.
2. A lot cheaper than GTX580M.
AMD 6990M - Disadvantages
1. Runs a lot hotter than the GTX580M
2. Worse driver support than Nvidia.
