Ionico Bios update to fix NVIDIA not detected
JulZak
After an update of windows 11, my nvidia gpu is not detected ( so I can't install any Nvidia driver ), nothing appear in device manager.
It seems that I could get a chance if I update my Bios.
Would you mind to help me to update my BIOS ?
My config below :
My config below :
You'd need to phone PCS directly, they're the only ones that have BIOS files.
What version of Windows are you on (enter the winver command to find out)
What was the update that caused the apparent problem?
Was your GPU working normally before the update?
