Ionico 17.3 - keyboard responsiveness issues?
xexuxjy
I ordered and received my Ionico laptop at the end of Feb, and while in general it's been very good I seem to be having a really annoying issue with the responsiveness of the keyboard. It seems to struggle with multiple key presses in certain situations, particularly around ctrl-c / ctrl-v combinations, alt-tabs and so on. Playing with repeat delay / rate in keyboard settings doesn't seem to make much difference. Just wondered if anyone had had any similar issues or advice.
Spec below.
Thanks,
Ionico Series: 17.3" Matte QHD 165Hz sRGB 100% LED Widescreen (2560x1440)
Intel® Core™ i7 Eight Core Processor 10875H (2.3GHz, 5.1GHz Turbo)
32GB Corsair 2400MHz SODIMM DDR4 (2 x 16GB)
NVIDIA® GeForce® RTX 3070 - 8.0GB GDDR6 Video RAM - DirectX® 12.1
128GB ADATA SX6000 LITE M.2 2280 (1800 MB/R, 1200 MB/W)
AC Adaptor
1 x 230W AC Adaptor
Ionico Series Integrated 91WH Lithium Ion Battery
1 x USB 3.2 PORT (Type C) + 3 x USB 3.2 PORTS
IONICO 17 SERIES RGB BACKLIT UK KEYBOARD
Windows 10 Professional 64 Bit - inc. Single Licence
INTEGRATED 1MP HD WEBCAM
Welcome Book
Macco26
Expert
My Ionico 17 seems pretty capable at that. No problems here.
Since you've received so early, mind you asking which BIOS you have? Maybe it's the very first January BIOS. There are 2 more version of this released by PCS, especially 1.09 (the latest I am aware of for Intel variants) is the one I'm rocking.
Since the EC part of the BIOS does control keyboard, lightning etc. if you have old BIOS (like 1.04 or 1.07) I'd recommend you to contact PCS and ask you sending the updated bits. Might be the solution.
