Ionico 15.6 Thin Horizontal and Vertical Green Line on Screen
Hello
Is there anyway to fix this? Laptop isnt even a week old and theres already a green block and a vertical and horizontal line originating from it.
Chassis & DisplayIonico Series: 15.6" Matte QHD 165Hz sRGB 100% LED Widescreen (2560x1440)
Processor (CPU)Intel® Core™ i7 Eight Core Processor 10875H (2.3GHz, 5.1GHz Turbo)
Memory (RAM)16GB Corsair 2666MHz SODIMM DDR4 (2 x 8GB)
Graphics CardNVIDIA® GeForce® RTX 3070 - 8.0GB GDDR6 Video RAM - DirectX® 12.1
1st M.2 SSD Drive1TB PCS PCIe M.2 SSD (2000 MB/R, 1100 MB/W)
Memory Card ReaderIntegrated Micro-SD Memory Card Reader
AC Adaptor1 x 230W AC Adaptor
BatteryIonico Series Integrated 62WH Lithium Ion Battery
Sound Card2 Channel High Definition Audio + MIC/Headphone Jack
Bluetooth & WirelessGIGABIT LAN & WIRELESS INTEL® Wi-Fi 6 AX201 (2.4 Gbps) + BT 5.0
USB/Thunderbolt Options1 x USB 3.2 PORT (Type C) + 3 x USB 3.2 PORTS
Keyboard LanguageIONICO SERIES RGB BACKLIT UK KEYBOARD
Warranty3 Year Gold Warranty (2 Year Collect & Return, 2 Year Parts, 3 Year Labour)
Promotional ItemGet 6 Months Founders Membership to GeForce Now w/ select RTX 30 Series Laptops
Promotional Cod
Promotional ItemGet Outriders with qualifying GeForce RTX Powered Laptop
Bhuna50
Its possible its a graphics card issue so would need to be RMA'd - is it always there or just during certain times - ie mid game?
Can you put a picture up?
Also - I suggest you remove promotional codes from your post.
Ive tried external displays and theyre fine. I think its the screen
Bhuna50
That good news its not the grfx card then - but even if its the screen, it will have to be replaced - i suggest as its still less than 14 days old, you get on the phone to PCS and talk to someone about it and get it RMAd - hopefully because it is so new, they will turn the RMA around quickly for you (probably jumping ahead of my RMA at the moment LOL).
I would totally agree, definitely call rather than emailing, as it’s new they should RMA it as a priority and as it’s clearly the screen, the troubleshooting is very quick and easy (that’s the longest part of an RMA)
Thanks guys- I did email but will call tomorrow aswell. Hopefully will get sorted quickly :)
