About 12 days ago I started having trouble monitoring the streams I do. They would hang about 3 times then freeze.
I thought I had solved the issue by adding some exceptions to Kasperksy but the problem has returned (it worked for a couple of days after I did the Kaspersky thing).
The download profile looks like this, and this clearly is causing the issue:
I connect via Wi-Fi which until the issue started has been great. The good bits there are 114 Mbps.
The issue does not seem to be happening on my laptop, so it seems to be something within my PC causing the issue.
My wi-fi card is shown as working properly and the signal bars are full. Could it be the wi-fi card failing or are there other possible causes?
I use OBS, but the same issue occurs using Shadowplay.
