Internal WiFi card replacement
Qrzysio
I use Clevo W650SF. BIOS show MS series as W65_67SF. Inside there is Intel Wireless-N 135 WiFi card. I would like to change it to a different one with 5 GHz frequency. I thought of Intel Dual Band Wireless-AC 9260 with Bluetooth 5.0 and I wonder if it will work with my laptop. Or maybe you can suggest something else?
The manual says inside my laptop should be Intel Wireless-N 7260, but for some reason, it is Intel Wireless-N 135.
https://www.intel.com/content/dam/w...t-briefs/dual-band-wireless-ac-9260-brief.pdf
The actual wireless card fitted to your laptop will be listed in the original spec. The N135 was a pretty standard card in many Clevo laptops, my old Optimus IV has one.
AFAIK the 9260 will physically fit, but I don't know whether you'd get 5GHz (or 802.11ac) from it with the antennas built in to the chassis. I'd strongly advise phoning PCS to double check before buying.
