My spec is:
CPU: i5 6600k 3.5GHz
GPU: Sapphire AMD Radeon RX 480 8GB GDDR5 RAM PCI Expess
RAM: Corsair Vengeance 2x 8GB DDR4 3000MHz
SSD: Crucial MX300 525 GB
HDD: Toshiba 3GB 7200rpm
Motherboard: MSI Z170A PC MATE
Networking: TP-LINK TL-WDN4800 N900 Wireless Dual Band PCI Express Adapter
PSU: Corsair Bronze VS 550w
Peripheral wise I also run an Oculus Rift, 2 sensor setup with touch controls. Wireless mouse+xbox control, wired keyboard. and the occasional memorystick/external HDD.
My issue is for months now I have had intermittent and seemingly random signal drops between my computer and any device it's plugged into for audio/visual output (via HDMI). The signal drop lasts approximately 1 second - ~10 seconds, and on the screen I am met by 'No Signal' briefly. But also affects the Rift if it's in use, causing the screen to freeze and the VR application to crash (very nauseating ) I have tried different HDMI cables etc...
I primary monitor was a TV (now broken maybe because of this problem) My HDMI on my TV now only gives a maximum resolution of ~640x480 for any device plugged into it (xbox1/360, and wont even recognise a laptop or my computer any more)
I am now using an older TV I was about to throw away, and experiencing the same issue between it and the computer. (again, no other devices seem affected.) -and this one hasn't broken....yet...
I have since noticed however that it seems to coincide with my freezer compressor kicking in/out, AND my boiler flicking on/off (These are both in my utility room). I have plugged the freezer into a mains socket from a different room and it seems to have eliminated that issue as far as I can tell (although it has been less than 24 hours at this point). But the boiler is still interfering.
It has been suggested in a different forum that it could be my graphics card failing, a resistor overloading occasionally or something. (I have had it less than a year) but I took that out and still had the same issue from the iGPU. I am now wondering if the PSU is unable to cope with the sudden brief change in load on my mains as the boiler/freezer do their thing. But again I have used a couple of online calculators and the wattage always falls into the low 400w's, with the CPU outputting 550w max.
Is there anything else it would be? or that I have overlooked?
It's only affecting my computer and any audio/visual device it's plugged into. (being rift or a tv/monitor)
If i plug my laptop into a TV as a second monitor I don't have these issues. And whilst this 'signal drop' is happening, the computer continues to function completely normally. ( I was streaming a game to my tablet to play from via steam and the dropout happened, but the game continued to play and function completely normally)
I should also add that everything is (now -yes it wasn't before <.<) connected to surge protectors. But it doesn't seem to help.
I am really stumped with this. Any advice or help would be greatly appreciated.
(Also on a side note, the laptop I mentioned above is an Optimus V 15" I bought in 2014. still going strong! -although the battery is kaput) :sorcerer:
