Installing windows Help
BartSoul
I’m in the process of Installing windows I’m at the part where I pick what drive to use when I click on a drive to delete it it comes up with “This partition might contain important files or applications from your computer to manufacture if you delete this partition any data stored on it will be lost”
What dose this mean I want to wipe all my drives befor I install is this possible or am I gonna break something please help thanks
It’s just warning you that you’ll lose all data on that partition.
BartSoul
Should I download windows onto my 256gb ssd witch is drive 2 because I don’t know witch is my ssd out of the other 2 because there the same size? Please help
BartSoul
I just put it on the 256gb ssd I think it was the fastest out of my other ssd plus I couldn’t tell witch was witch cause the ssd and hdd was the same space
BartSoul
I can all ready tell my pc is running a lot better I think they messed up and forgot to finish my pc befor they sent it back out
