installing adobe
hi please see below for my laptop stats; I need some advice. im gonna be using it for video editing and photoshop mainly, so can someone please tell me where I would be best to save the adobe programs. currently the OS is being installed on the m2 drive.
Octane Series: 17.3" Matte 4K LED 60Hz 72% NTSC Widescreen (3840x2160) (No G-Sync)
Intel® Core™ i7 Six Core Processor i7-8700 (3.2GHz) 12MB Cache
32GB Corsair 2666MHz SODIMM DDR4 (2 x 16GB)
NVIDIA® GeForce® GTX 1080 - 8.0GB GDDR5 Video RAM - DirectX® 12.1
1st Hard Disk
2TB Samsung 860 EVO 2.5" SSD, SATA 6Gb/s (upto 550MB/sR | 520MB/sW)
512GB SAMSUNG 970 PRO M.2, PCIe NVMe (up to 3500MB/R, 2300MB/W)
AC Adaptor
1 x 330W AC Adaptor
Octane Series 8 Cell Lithium Ion Battery (82WH)
Bluetooth & Wireless
4 x USB 3.0 Ports + 2 x USB 3.1 Type C Ports
OCTANE SERIES BACKLIT UK KEYBOARD WITH NUMBER PAD
Notebook Mouse
INTEGRATED 2.0 MP FULL HD WEBCAM
Promotional Item
FREE Assassin's Creed: Odyssey with select SAMSUNG SSDs!
Just a word of caution about the informative link posted by Oussebon...
Where they talk about using multiple drives to improve performance these must be separate physical drives, you won't get those benefits from partitioning a larger drive. Even though the OS reports a partitioned drive as separate volumes, at the hardware level they are all one drive and there can only be one read/write operation in progress to a drive at a time. Drive partitioning is a data management tool, not a performance tool.
As Oussebon says, all your installed programs should go on the SSD.
As you can see I have three drives. All three are ssd’s will it make a differences which one I install it too?
You want the programs on the fastest SSD or else there wasn't much point buying it...
And do refer to the article.
