Install games on HDD or SSD?
bumblegames
Hi everyone. Just got my first gaming desktop from PCS. I was just wondering which drive I should use to install Steam, Origin and games in general?
I have a 1TB SEAGATE BARRACUDA SATA-III 3.5" HDD, 6GB/s, 7200RPM, 64MB CACHE and a 1TB PCS PCIe M.2 SSD (2000 MB/R, 1100 MB/W) although one is named Windows and the other is named New Volume in my files. I'm guessing the first one is the SSD as I think that's what the OS was installed on but I just wanted to double check.
Here's the main specs if needed.
STANDARD AMD CPU COOLER
steaky360
You can install games on either, I'd suggest potentially installing games you're regularly playing onto the SSD and storing any games you don't want to have to download at a pinch on the HDD - Steam lets you transfer games from one device to another quite easily nowadays.
bumblegames
I was thinking the same thing. So, would the SSD be the drive called Windows? Thanks for the advice.
Rakk
The Awesome
When you ordered it would've asked you which drive you wanted Windows on, by default it would've picked the M.2 SSD drive in the dropdown list, so unless you specifically went against the configurators recommendation Windows should be on the M.2 SSD
bumblegames
Yeah, I went with the recommended drive. Thanks again 😊
