Hello all,
Sorry if this is a bit long,
Anyway I'm look to get a new laptop with in the next few days and I just wanted a little bit of advice, my budget is around £1,000 mark (quite willing to go above).
This is what i'm currently looking at
Vortex II-15: 15.6" Full HD LED Backlit 16:9 Widescreen (1920x1080) Super Clear Glossy
Intel® Core™i7 Quad Core Mobile Processor i7-2720QM (2.20GHz) 6MB Cache
8GB SAMSUNG 1333MHz SODIMM DDR3 MEMORY (2 x 4GB)
1.5GB nVIDIA® GeForce® GTX 460M - DirectX® 11 (15.6" Vortex II)
Memory - Hard Disk
320GB WD SCORPIO BLACK WD3200BEKT, SATA 3 Gb/s, 16MB CACHE (7200 rpm)
Bluetooth & Wireless
GIGABIT LAN & INTEL® CENTRINO® ULTIMATE-N 6300 WIRELESS upto 450Mbps
The most demanding application the laptop will be used for will probable be autocad (3d). Keeping that in mind I also want the laptop to be quite future proof which happens to be one of the deciding factor for choosing PCS.
Anyhow the problem is in regards to ram and I have read a few threads but none really answers my question. Basically I was looking on intel's website and they suggest that the processor that I have choosen will only support 8gb @ 1333mhz and yet I have seen that 16gb @ 1333mhz and 8gb @ 1600mhz seems to run fine with this processor. I know using its not advisable to use different types of ram but what about using 16gb @ 1600mhz, im guessing this is not possible but is there any room to upgrade the 8gb @1600 mhz?
Another little concern I have which is going to make me sound like a bit of a noob but in my spec I have decided not to have an os installed because my uni will give me a free copy of windows 7 pro (x64). I have installed many operating systems on my laptop before but never on a completely new machine and I just want to make sure its going to be as easy as putting in the cd and letting it run?
Again sorry for making such a long post I just want to be sure before I purchase anything.
I would also like say how impressive your service appears and if all goes well ill defiantly be a returning customer
all the best
paddy
Memory - Hard Disk
all the best
paddy
