Incompatible HDMI cable
peter2108
My Intel NUC Ultra Small Form Factor Case i7/HDD (NUC10I7FNH3) has an HDMI port that is incompatible with the HDMI cable supplied with my AOC U3277FWQ monitor. I guess I need an adaptor. But what is the specification of the HDMI port on the PC?
Attaching a pic of the HDMI cable with the monitor cable:
and the mioni computer port:
What a bugger ....
peter2108
Error on error. They did not say they were sending HDMI, they said DisplayPort, but they hid it. Any advice about HDMI cables? I don't want another screw-up .....
steaky360
Don't get one longer than you need but you don't need to spend much really if you're not doing anything novel with it (like burying it in a wall or anything).
An amazon basics cable should work fine in my experience or anything of that sort of price range.
