I'm considering the 2080ti GPU
Sidmouth
Rather than create a new thread I'll use this one.
I'm considering the 2080ti GPU.
Would a 750w power supply suffice in powering my system still with the 1080 swapped out for the 2080ti. Bearing in mind everything else in the system based on the list below. My spec is still the same. They recommend a 650w power supply however my system already uses 580w according to the rundown on my order page. What's everyone's thoughts on it. Many thanks.
CORSAIR CARBIDE SERIES™ AIR 540 GAMING CASE
Overclocked CPU Overclocked Intel® Six Core i7-6850K (3.6GHz @ up to 4.3GHz)
OC BIOS FIle Download Overclock BIOS File
Motherboard ASUS® ROG STRIX X99: ATX, USB 3.1, SATA 6 GB/s, RGB Ready
Memory (RAM) 16GB HyperX SAVAGE DDR4 3000MHz (4 x 4GB Kit)
Graphics Card 8GB EVGA GEFORCE GTX 1080 FTW GAMING - DVI, HDMI, 3x DP - GTX VR Ready!
1st Hard Disk 2TB Samsung 850 EVO 2.5" SSD, SATA 6Gb/s (upto 540MB/sR | 520MB/sW)
2nd Hard Disk 2TB WD BLACK 3.5" WD2003FZEX, SATA 6 Gb/s, 64MB CACHE (7200rpm)
1st M.2 SSD Drive 512GB SAMSUNG SM961 M.2, PCIe NVMe (up to 3200MB/R, 1700MB/W)
Power Supply CORSAIR 750W CS SERIES™ MODULAR 80 PLUS® GOLD, ULTRA QUIET
Processor Cooling Corsair H100i V2 Hydro Series High Performance CPU Cooler
Wireless/Wired Networking 10/100/1000 GIGABIT
LAN PORT (Wi-Fi NOT INCLUDED)
USB Options MIN. 2 x USB 3.0 & 6 x USB 2.0 PORTS @ BACK PANEL + MIN. 2 FRONT PORTS
I've created a separate thread for you because not everyone who can answer your questions here would visit the PC BIOS thread. One thread per topic is a good idea. :)
The PSU should suffice. But obviously don't even think about buying it until reviews with performance information are out :)
What do you use the PC for, and if gaming what monitor do you pair it with?
Sidmouth
That's good to hear, so the pc is used for gaming. I'll record and stream on occasion.
The monitor I currently use is the:
ASUS PG348Q 34" 100Hz G-Sync Curved Monitor With IPS Panel
Resolution sits at 3440x1440. Close to 4k
Then the 2080 ti might be a good fit, if you're finding the 1080 not adequate for what you want from it. We shall see when reviews are out (not sure when NDA lifts, but my guess will be on release day, 20th Sept)
