If approved by community, it's going to be ordered next week
Hexas
Intel® Core™i5 Quad Core Processor i5-3550 (3.3GHz) 6MB Cache
ASUS® P8Z77-V LX: USB 3.0, SATA 6GBs, ATI®CrossFireX
2GB AMD RADEON™ HD7850 - DVI,HDMI,2 mDP - DX® 11, Eyefinity 4 Capable
Monitor
IIYAMA E2273HDS 22" LED WIDESCREEN, HDMI/DVI-D 1920x1080 (£129)
Price: £909.00 including VAT and delivery.
Basically, I need inexpensive PC, with medium-high settings in games. Probably gonna crossfire in the future. No need for win 7, got my own, but I need a monitor, heard good thing s about Iiyama. I'm going to buy keyboard and mouse separate. Any suggestions.
vanthus
Member Resting in Peace
Very nice build,Iiyama monitors seem to be very good according to reports,
mouse & keyboard? well i've tried some "fancy ones" but the the basic ones suit me fine.:)
Corfate
Monitor
If you can, go for the 570 GPU :)
Wozza63
Biblical Poster
i agree with the suggestions above from tom and corfate, id also say upgrade to the 24" if you can, its not too much more and its much bigger and also has a 2nd HDMI (which is a big bonus for me as i need one for my xbox)
For keyboard, I can definitely say that the Arctosa is brilliant value for money, i have it myself, the keys are much flatter than other keyboards making it much easier to type, the only thing it lacks is backlights which is available on the lycosa if you want backlight
As for mouse, my mouse is good, id recommend it although its probably not the best for the price out there (gigabyte M8000X) although ive heard great things about the RAT7 and the white one looks awesome, so im considering upgrading to that
bg92
Expert
Stick with the amd 7850 as it has more vram than a gtx570, also it consumes less power so you could run two of these on a 650w power supply.
The only thing that I would reccomend would be changing the case to haf912 as it's a great case given it's price.
vanthus
I would stick with the 7850,if you change to the 570 you wont be able to SLI in future with the motherboard you have selected.I have a 5870 & it can still handle anything i throw at it,so dont believe all you hear about Nvidia being all that superior,not true.:)
dangro474
Your build looks fantastic and I can attest to the high quality of Iiyama monitors. I recently purchased the 24" panel for my cousin priced at £165 and it almost leaves me embarassed by my £450 inferior Dell panel -_-
