i7-7700k overclock
charlieb90
Hi I have just brought this new gaming PC of PC specialist waiting for it to be delived still. How much will they overclock the cpu? I'm new to PC gaming aswell so bare with me please lol
NZXT NOCTIS 450 MID-TOWER GAMING CASE (BLACK/RED)
Overclocked CPU Overclocked Intel® Core™i7-7700k Quad Core (4.20GHz @ up to 4.8GHz)
Motherboard ASUS® ROG MAXIMUS IX FORMULA: ATX, LG1151, USB 3.1, SATA 6GBs - RGB Ready!
Memory (RAM) 16GB HyperX PREDATOR DDR4 3200MHz X.M.P (2 x 8GB)
Graphics Card 8GB EVGA GEFORCE GTX 1080 FTW GAMING - *** FREE EVGA Powerlink ***
1st Hard Disk 500GB Samsung 850 EVO 2.5" SSD, SATA 6Gb/s (upto 540MB/sR | 520MB/sW)
Power Supply CORSAIR 850W RMx SERIES™ MODULAR 80 PLUS® GOLD, ULTRA QUIET
Processor Cooling Noctua NH-U14S Ultra Quiet Performance CPU Cooler
LED Lighting 50cm Red LED Strip
Extra Case Fans 1x 120mm Apache Black Quiet Fan (fitted to extract from rear/roof)
Rakk
The Awesome
They will try and overclock it to 4.8, but if they can't get it stable at that speed it may be slower - it mostly depends on the silicon lottery I'm afraid.
5ghz stable with an air cooler? Why not jus rely on the turbo boost? Any specific reason for more than that?
The OC they can reach will vary from chip to chip (silicon lottery as mentioned above). I imagine they go for 4.8GHz and advertise that figure as it's reasonably feasible to reach that on most chips, plus as it's a reasonably middle of the road OC it shouldn't present too many temperature issues, even given the quite high temps that Kaby Lake i7s can give under some loads.
The OCed builds are only about ~£10 more than the stock ones, so it may be a quite reasonable compromise. I haven't read much about Kaby Lake OCing in detail, but 5GHz did seem to be a limit for a lot of the initial Kaby Lake reviews I read.
They do offer upto 5GHz in the liquid systems: https://www.pcspecialist.co.uk/computers/intel-z270-liquid/
There's nothing stopping you upping the OC yourself ofc :) As long as you're comfortable with the warranty implications.
