I7 2700K Quad Core 3.50GHZ 8MB + HD Graphics?
skipper8472
How long has the I72700K been out just looking threw the intel config your own on here and thats an option but just wanted to no how long its been out and if its any good?. Like i say i want a future proof PC where realy i only need to upgrade the graphics card in the next 5 years as well as upgrade to windows 8.
Thanks.
skipper8472
ANTEC NINE HUNDRED TWO V3 - UK, The Ultimate Gaming Case, Evolved
Intel® Core™i7-2700k Quad Core (3.50GHz, 8MB Cache) + HD Graphics
2GB AMD RADEON™ HD6970 - 2 DVI,HDMI,2 mDP - DX® 11, Eyefinity 4 Capable
12x BLU-RAY ROM DRIVE, 16x DVD ±R/±RW (£45)
COOLIT ECO II A.L.C (ADVANCED LIQUID COOLER) (£59)
£1104.17 ex VAT.
£1325 inc VAT and Delivery.
I could proly save a thew £ by dropping the bluray but what is this PC like. How noisy would the PSU be etc?.
Thanks.
tom_gr7
Life Serving
the psu will be pretty much silent, i have never heard my corsair psu.
change i would make are, change the cooler to the titan fenrir, as good as the eco but without the worry of coolant leaking.
also i'd go for a 1.5gb 580, if you can afford it.
skipper8472
Thanks for the reply.
How long have the I72700K been out?.
Think the 1.5GB 580 is pushing my limit :D
skipper8472
Ok what else could i drop so the price isnt as much but still top notch PC :D
BTW im going to get the PC with a new Hard drive and windows7 Home installed but i do have a 650GB hard drive with windows7pro on it. Its a sata 2 hard drive will the sata 2 harddrive fit into this PC?. You might say drop the Hard if you already have one but i might as well have 2 then got a fair bit of room to install all my stuff. thanks again
skipper8472
ASUS® P8Z68-V PRO: USB 3.0, SATA 6GB/s, NVIDIA®SLI™, ATI®CrossFireX™
1.5GB NVIDIA GEFORCE GTX 580 - 2 DVI, HDMI, DP - 3D Vision Ready
Changed the HD to 750WD Black but like i say i do have a 650WD Black with windows7pro already on as well. and gone for the 1.5GB 580
Price for this PC System:
£1138.33 ex VAT.
£1366 inc VAT and Delivery.
Thats if i can have my Sata2 WDBlck 650GB HD in as well.
