i7-2600k GTX 590 machine
Pyrotenax
Here's what I have put together , but am a little worried the big cooling rad might not fit in. Can someone confirm there is enough space / headroom for the Advanced Liquid Cooler please ?
CORSAIR OBSIDIAN SERIES™ 650D GAMING CASE
Overclocked CPU
Overclocked Intel® Core™i7-2600k Quad Core (3.40GHz @ max 4.80GHz)
ASUS® MAXIMUS IV EXTREME-Z: INTEL Z68 ROG MOTHERBOARD
3GB NVIDIA GEFORCE GTX 590 - 2 DVI,mHDMI - 3D Vision Ready
240GB OCZ VERTEX 3 SSD, SATA 6 Gb/s (upto 550MB/sR | 520MB/sW)
12x BLU-RAY RE-WRITER DRIVE, 16x DVD ±R/±RW (£79)
CORSAIR 750W PRO SERIES™ HX750-80 PLUS® SILVER MODULAR (£116)
COOLIT ECO II C240 A.L.C (ADVANCED LIQUID COOLER) (£99)
ARCTIC COOLING MX-3 HIGH THERMAL CONDUCTIVITY COMPOUND (£9)
ONBOARD GIGABIT LAN & WIRELESS 802.11N 300Mbps PCI-E CARD (£19)
Genuine Windows 7 Ultimate 64 Bit - inc DVD & Licence (£146)
Monitor
IIYAMA E2473HDS 24" LED WIDESCREEN, 2 x HDMI/DVI-D HD 1920x1080 (£169)
2nd Monitor
3rd Monitor
Speakers
LOGITECH Z623 2.1 SPEAKERS - 200W RMS & THX®-Certified (£149)
Surge Protection
6 Socket Compact 2M UFO Surge Protector (£9)
3 Year Gold Warranty (2 Year Collect & Return, 2 Year Parts, 3 Year Labour) (£69)
SATURDAY DELIVERY TO UK MAINLAND (BEFORE 12 NOON) (£19)
Len
yes you could overclock it your self, but then you would lose your warranty, if you let PCS do it, it's not alot more money and will still be under warranty
Pyrotenax
how would they even find out ? you would only be returning the failed component via RMA , not the complete system anyway :)
Rakk
The Awesome
You do not automatically lose your warranty if you overclock your CPU.
You lose it if your overclocking attempts are the cause of the breakage/failure
But yes, PCS will overclock it for you if you want, you need to use the Overclocked PC's configurator to build it, it'll force you to have relevant cooling and gives you the choice to use better thermal paste on your CPU.
Pyrotenax
Thanks , I missed that bit out about the "Overclocked PC's configurator" , I shall edit my OP with updated info , and thanks Len for the additional info :0)
Wozza63
Biblical Poster
id probably get a case with better cooling, such as the Sniper or HAF-X, both have really good cooling, just choose whichever you prefer
otherwise, that 590 will get extremely toasty
or at least get something with a side fan, they are the most important thing to have with latest graphics cards
faihaf
oc i2600k GTX590 AND OCZ SSD asking for trouble. i had this system and was rma the same day.
i would go for normal i2600 gtx 580 3gb one and intel ssd
Pyrotenax
hmmm , checking OCZ support forums and there are loads of people with BSOD's and other problems related to SSD :/ , maybe intel is the way to go , but i want to stick with i7-2600k tho
Rakk
The Awesome
this guy joking its like £3255
Although I cover never justify spending so much on a machine myself, many do, so just because it is very hefty don't always assume its a joke :)
I've seen other specs in these forums that have been heftier.
Wozza63
Biblical Poster
Edit by Rakk: Wozza, please don't clutter up threads with stuff that is not relevant to the post ....
Pyrotenax
It is no joke , but i am currently re-evaluating my choices of....
1) Monitor(s) : ghosting issues , I may even go for 27" Dell Ultrasharp instead of triple setup
2) SSD : OCZ just seems to be a complete nightmare of problems if you check their forums
3) Ram : 8GB instead of 16GB
