i5 or i7 for non-gaming desktop
weare one
Hi all
I’m looking to replace my desktop and would like some advice on whether or not a i5cpu will suffice my needs or if I should go for a i7cpu.
I am not a gamer but I usually have running Photoshop/Word up to 5/6 windows/Excell and Firefox with up to 10 tabs open.
Also will a dedicated graphic card be necessary, although I have always had one.
Any advice would be appreciated.
weare one
Hi keynes
Thanks for your quick reply
I appreciate what you say about Photoshop, its and old version 7.0 but has worked perfectly ok on this auld Pentium D cpu 3.2ghz and a ATI Radeon HD 4770 for many years, so was wondering if i7 was necessary.
Budget between £1000 and £1400 for base unit although would rather keep it lower as will add new screen at a later date.
Photoshop appears not to benefit from an i7, or at least not from an i7's hyperthreading - it might benefit from an i7's slightly higher frequency. However it seems likely going by that that an OCed i5 would be best.
weare one
Interesting……….thanks for the info and the link Oussebon :cool:
