I need help
DavidK
My pc arrived yesterday and the Bluetooth and wifi are terrible. With the Bluetooth, my earphones cant stay connected unless I basically press my face to the pc side panel. With my phone, I can basically be in my nabours house and the earphones still work will still work. The wifi won't connect either. I assume my network card is the issue. I have the WIRELESS INTEL® Wi-Fi 6 AX200 2,400Mbps/5GHz, 300Mbps/2.4GHz PCI-E CARD + BT 5.0 . Is there any way I can connect to the motherboard wifi and Bluetooth? I have the ASUS® STRIX B550-F GAMING (DDR4, USB 3.2, 6Gb/s) - ARGB Ready!
3qtrsamericano
Have you plugged in the two antenna's which come with the PC? I don't think the MOBO has WiFi so that won't do you any good.
Steveyg
No i didnt know I had too. How do i do that. Sorry for stupid question
You take the antennae from the box you received mate and screw them on the back of the computer. You'll see the two spots they get screwed on
It's quite sensitive so if you make them too tight it'll not work correctly or if there too loose it wont work correctly either. Just keeping messing with it you'll find it but it's a little fiddly
DavidK
Thanks so much for the help guys that fixed the Bluetooth and the wifi now connects is there any reason it might still be slow. I use toi get 16mb download on steam on my old laptop. Now i can barely even get three. Do i need to face the antenna a certain way or something
Steveyg
They can be really sensitive mate, It'll take some adjusting and stuff to get it working right.
can you post the full spec from your orders page and also a screenshot of the windows update page
DavidK
Case LIAN LI LANCOOL 215 GAMING CASE
Processor (CPU)AMD Ryzen 5 5600X Six Core CPU (3.7GHz-4.6GHz/35MB CACHE/AM4)
MotherboardASUS® STRIX B550-F GAMING (DDR4, USB 3.2, 6Gb/s) - ARGB Ready!
Memory (RAM)16GB Corsair VENGEANCE RGB PRO DDR4 3200MHz (2 x 8GB)
Graphics Card12GB NVIDIA GEFORCE RTX 3060 - HDMI, DP
1st Storage Drive250GB Samsung 870 EVO 2.5" SSD, SATA 6Gb/s (up to 560MB/sR | 530MB/sW)
Change to: 500GB Samsung 870 EVO 2.5" SSD, SATA 6Gb/s (up to 560MB/sR | 530MB/sW)
2nd Storage Drive1TB SEAGATE BARRACUDA SATA-III 3.5" HDD, 6GB/s, 7200RPM, 64MB CACHE
DVD/BLU-RAY DriveNOT REQUIRED
Power SupplyCORSAIR 550W TXm SERIES™ SEMI-MODULAR 80 PLUS® GOLD, ULTRA QUIET
Change to: CORSAIR 750W TXm SERIES™ SEMI-MODULAR 80 PLUS® GOLD, ULTRA QUIET
Processor CoolingPCS FrostFlow 100 RGB V3 Series High Performance CPU Cooler (AMD)
Change to: PCS FrostFlow 100 V3 Series High Performance CPU Cooler (AMD)
Operating SystemWindows 10 Home 64 Bit - inc. Single Licence [KK3-00002]
Change to: Windows 10 Home 64 Bit - inc. Single Licence [KUK-00001]
BrowserGoogle Chrome™
Delivery2 - 3 DAY DELIVERY TO REPUBLIC OF IRELAND
Build TimeStandard Build - Approximately 14 to 17 working days
This? It says there's an update is that the issue
YES!
Your Windows system is missing a bunch of updates and drivers that those updates will install. Keep running Windows Update until no more updates are found. Then click on Optional Updates and look for driver updates in there. Install those too.
