I need a new SSD
BK2801
I have had my pc for over 4 years now and ive been using a 500gb ssd aswell as a 2TB hard drive which is just terrible now. im looking to upgrade my ssd to roughly 2TB however more is also good. my budget is £200.
Motherboard - ASUS® ROG STRIX Z390-F GAMING: ATX, LGA1151, USB 3.1, SATA 6GBs - RGB Ready
SSD - 500GB SEAGATE BARRACUDA 120 2.5" SSD, (up to 560MB/sR | 540MB/sW
If anyone has any suggestions id be grateful.
Thanks.
I believe that motherboard supports gen3 m.2 SSDs, so if only one slot is used you can simply buy a 2TB gen3 m.2 NVMe SSD of your choice.
You can either go into your account and use the upgrade service, or simply buy one online. Crucial P3 Plus, Solidigm P41 Plus, WD SN770 Black are all decent (gen 4) options, at good prices (around £100) you won’t see their full performance on your system, but gen 3 ones aren’t any cheaper anyway.
Crucial P3 Plus
Solidigm P41 Plus
WD SN770 Black
