Hyte Y70 Touch
I've been generally very impressed with Hyte, it's a tough market to break into, the PC case market, very hard to remain competitive price wise while having good performance.
For me the Y40 was too much of a compromise. But the Y60 ticked all the boxes.
Well they're now out with a new one called the Hyte Y70 which has a silver bullet to it
well i must say thats cool and I want one
pre order 349.98
same price in black
pre order 349.98
same price in black
The screen must be £100 on its own though, for quite a high end case, I don’t think that’s bad at all. Early Lian Li’s were more like £450 - 650, and that’s when things were a lot cheaper
future of cases, do like the idea of an all white build with this case, pretty interesting.
imagine if you could order your vinyl records on the screen in the case while playing your favourite game,
the matrix gifs Page 9 | WiffleGif
JUNI0R
pre order 349.98
same price in black
Honestly don't think this is outrageous. Expensive sure, but it's got a cool gimmick to make it worth the price.
Just a reminder the Corsair 5000T was (and god knows how but still is) £350 at launch. I know which one I'm taking!
Think the only issue for the Y60 is it's only triple slot vertical mount, which is an issue for these new chonker 4090's. Otherwise it's an incredibly attractive prospect for a high end case imo. Good they've fixed it with the Y70 now being 4 slot :)
Yeah, absolutely, that was certainly an issue with the Y60, it was released just before the 4000 series chonkers.
The other thing I wish they'd do would be to make the GPU bracket more configurable like on the Lian Li O11 Dynamic XL where you can put it in various positions in the case.
I really like that. The airflow design looks absolutely fantastic. If the dust control is decent then I think that case could have it all. The only negative would be the limitation due to size and wanting the thing on your desk :LOL:
I love the design touches though, great bit of kit. Would like to see it put through its paces with GN to see what the airflow turbulence is like. In my head I think it should work well with the side pull and rear extract.
Just caught the end of Jayz vid. Curious to see what they have coming next, and how awesome would playing Tetris on your case be :ROFLMAO:
at 6.27 this creator is talking about thermals, his words were "Im not going to in depth because of tech Jesus" referring to GN :ROFLMAO:
As much as that was a funny snipe at GN, the information he did offer with thermals was less than useless. Hottest CPU on the planet running on a couple of cores with a gaming load and then giving an indication of any sort of temps is just pointless.
I wouldn't be too worried about CPU temps personally, most would recommend AM5 anyway which shouldn't cause too many issues. The real measurement required is the case internal temp and the GPU temps in line with it.
It needs GN, GN are the only guys I go to for thermal tests. They’ll definitely pick this up, this case is such a branch forward in case design that it’s getting a lot of attention.
