How to setup SLi(help)
Markola727
Hello guys. i received my PC yesterday and its just Awesome, thank you PCS :).
OK gonna get to the point, i am wanting to SLI my GTX 670 in a few weeks and i have been watchin tutorials on YouTube how to install. I am happy with most of the things i have to do, I'm just confused about one thing...where is the lead what connects to my second graphics card. I believe its called a PCI-E or something. Will it be hidden somewhere inside my case or do i have to buy this lead. totally confused because i cant see it on my PC.
I have the SLI bridge ready and all i need to do it order my second gtx 670 but i cant find the PCI-E lead. Any help will be appreciated :)
Thank you.
PS, hope this makes sense lol.
vanthus
Member Resting in Peace
All you should need to do is connect the card to the PCI-E slot then connect power cable/s to it and connect the cards with the bridge.
steaky360
What PSU do you have? If its modular then it will be in your welcome pack with a number of other cables, if not then it will be coming from your PSU :)
The one on the left is modular (the cables unplug) the one on the right is not modular (they are all permanently attached).
vanthus
There should be spare power cables inside the case unless you have a modular PSU,in which case cables should be supplied in your welcome pack.
Edit. Lol,I'm getting slow.
Markola727
Power Supply CORSAIR 750W ENTHUSIAST SERIES™ TX750 V2-80 PLUS® BRONZE
there are some cables in my welcome pack, but again where do i connect these cables too lmaooo sorry guys. i feel so noob :D
I think its not modular. just wires coming out of the PSU.
vanthus
That's a non modular PSU,there should be spare power cables inside the computer case.
I don't think it is modular, the power cables should come from the PSU inside your case.
steaky360
There might be enough cables already attached, however if not, you will need 2x the 6pin cables (the black slots on the right)
Edit, however as Vanthus and Keynes have pointed out its non-modular so they should be hidden away somewhere inside your case :)
If you follow the cables out from the PSU you should be able to see where PCS have stashed them.
Tom DWC
Follow the cables from your current graphics card back to the power supply, you need to connect another set of these cables to the new card, which will be attached to your power supply already (they might be tucked away somewhere so you might need to cut a cable tie or something).
You can put the bridge across from either of the two points on the cards.
*I'm being slow.
Markola727
Ok i think i no what im doing now. im guessing these leads what are tucked away are on the other side of the case. (behind the other side panel?)
There are no loose wires to be seen in the case.
steaky360
Most likely, you are looking for 2 of these :
NOTE: You might find the connections on your PSU are like the ones on the left or the right, they are both ok. They might not have PCI-E written on them either.
Markola727
Yeh im guessing there on the other side of the case tucked away behind the side panel. Thank you all for the help and i will be back when i get my new graphics card for more pointers if im struggling lol. i tend to panic when i don't no what im doing lol :)
Markola727
Hello guys, I'm back!! lol. Next tuesday im going to be buyin my second GTX 670, but im wondering if this card thinking about buying is gonna be better for SLI becuase of its fans. Also would like to no if its going to fit ok?
Here is the Card im going to Buy http://www.ebay.co.uk/itm/Gigabyte-...raphics_Video_TV_Cards_TW&hash=item4d0bc082dc
COOLERMASTER CM STORM TROOPER - GAMING ENTHUSIAST CASE
ASUS® P8Z77-V LK: PCI-E 3.0 READY, SLI, CROSSFIREX
4x BLU-RAY ROM DRIVE, 16x DVD ROM (£27)
CORSAIR 750W ENTHUSIAST SERIES™ TX750 V2-80 PLUS® BRONZE (£89)
2 x 12CM Black Case Fan (configured to extract from rear/roof) (£9)
PCS EXTRA-CARE DIAMOND DELIVERY - MON-FRI, PRE-NOON (£9)
Miscellaneous
FREE METRO: LAST LIGHT GAME with GTX 660 & UPWARDS GPUs!
