How to check what im OC to?
jacktimson
ive found out, its at 4.6 ghz :), ive got the i7 2600k :), im using prime95 and cpu-z. anyone know how i can check the ram is at 1600 or should i just assume it is?
Does cpu-z tell you your cpu temperture? cant seem to find it :S
mpv
I'm using Real Temp 3.67 to track my CPU and GPU temps. It also tells you what speed your CPU is running at and what load % along with other nice things like base clock and multiplier. It shows current and max temps for both CPU and GPU which is nice.
Different programs will report different temps though so be prepared for some variability (a cause of frustration for me).
Congrats on a righteous overclock though :)
