How to change ARGB Coolermaster fan colours?
romanxx17
Hi, I recently got a custom PCS build with a COOLERMASTER MASTERBOX TD500 MESH RGB GAMING CASE and Asus Rog Strix motherboard, but I am unsure how to change the colours of the front 3 fans of the case which are CoolerMaster fans. The fans are default green currently. Do I need to manually connect a controller since they dont seem to show up on the ASUS Aura and Armoury Crate apps.
Cheers
ChrisCooney
Hi Roman!
Is there a reset button on the front of your case? Sometimes PCS wire up the fans to this, rather than into the mobo.
