I'm looking for a new tower, in anticipation of an upgrade to Windows 11. I got my last PC from PCS and it's worked flawlessly for 7 years (Skylake processor). But I'm ready to move on, especially since I want to donate this one.
It's been a while. The following things are most important to me. This will be a productivity machine, rather than a gaming one, though a bit of light gaming would be nice. It needs to be quiet and fast. I usually have a lot of programs open at the same time, with a bunch of tabs on the tabbable ones. This includes a couple of graphics programs, PaintShopPro, maybe The Gimp and usually ON1 or something of that nature.
I have a 28 inch 4k Samsung monitor which my current pc doesn't handle well - I'm currently running it at 30 hertz, which is pretty nasty.
So - is this a good idea? My budget is a max of £2,500, but this build comes well under that.
CORSAIR 175R RGB MID TOWER GAMING CASE
AMD Ryzen 5 7600 Six Core CPU (4.0GHz-5.2GHz/38MB CACHE/AM5)
ASUS® TUF GAMING B650-PLUS (DDR5, USB 3.2, 6Gb/s) - ARGB Ready!
32GB Corsair VENGEANCE DDR5 4800MHz (2 x 16GB)
12GB NVIDIA GEFORCE RTX 3060 - HDMI, DP, LHR
512GB PCS PCIe M.2 SSD (3300 MB/R, 2200 MB/W)
CORSAIR 550W CV SERIES™ CV-550 POWER SUPPLY
LED Lighting
50cm RGB LED Strip
Microsoft® Edge
Promotional Item
Get Marvel's Midnight Suns with select GeForce RTX 30 Series GPUs!
Welcome Book
Logo Branding
PCSpecialist Logo
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am5-pc/Dwcz5c2SFK/
PCSPECIALIST - Configure the AMD Am5 PC to your ideal requirements.
PCSpecialist is an award-winning manufacturer of high quality custom PCs & Laptops. Configure the AMD Am5 PC to your ideal requirements.
LED Lighting
50cm RGB LED Strip
Microsoft® Edge
Promotional Item
Welcome Book
Logo Branding
PCSpecialist Logo
