HotKey Software
Joners
Ive got a Optimus 13.3" Laptop (Clevo W230ST) and have found that the HotKey Software has started to crash. it appears to be after a recent Windows Update (running 8.1 pro).
Ive been unable to get it working again, ive done a fresh install, installed HotKey, works ok. Then update and it breaks again.
Got the following in the event logs.
Im using HotKey 8.0153 (according to Programs and Features).
___________________________________________________________________________________
Faulting application name: Hotkey.exe, version: 8.0.0.137, time stamp: 0x52d08e6e
Faulting module name: brightness.dll, version: 1.0.0.1, time stamp: 0x50aa6e98
Exception code: 0xc0000005
Fault offset: 0x00001905
Faulting process ID: 0x1138
Faulting application start time: 0x01d0c3b723f31732
Faulting application path: C:\Program Files (x86)\Hotkey\Hotkey.exe
Faulting module path: C:\Program Files (x86)\Hotkey\brightness.dll
Report ID: 65722ea8-2faa-11e5-825a-0c8bfdd97389
Faulting package full name:
Faulting package-relative application ID:
Log Name: Application
Source: .NET Runtime
Date: 21/07/2015 14:14:20
Event ID: 1026
Task Category: None
Level: Error
Keywords: Classic
User: N/A
Computer: W230ST
Description:
Application: Hotkey.exe
Framework Version: v4.0.30319
Description: The process was terminated due to an unhandled exception.
Exception Info: System.AccessViolationException
Stack:
at HotKey.CallingVariations.GetBrightness()
at HotKey.ControlCenter.UpdateForm()
at HotKey.ControlCenter.radioButton6_CheckedChanged(System.Object, System.EventArgs)
at System.Windows.Forms.RadioButton.OnCheckedChanged(System.EventArgs)
at System.Windows.Forms.RadioButton.set_Checked(Boolean)
at HotKey.ControlCenter.myDevice_ControlCenter_change(System.Object, System.EventArgs)
at HotKey.Device+EventHandler.Invoke(System.Object, System.EventArgs)
at HotKey.Device.OnChange(HotKey.ControlCenterEventArgs)
at HotKey.Device.set_Status(Int32)
at HotKey.HotKey.ControlCenter_Tick(System.Object, System.EventArgs)
at System.Windows.Forms.Timer.OnTick(System.EventArgs)
at System.Windows.Forms.Timer+TimerNativeWindow.WndProc(System.Windows.Forms.Message ByRef)
at System.Windows.Forms.NativeWindow.Callback(IntPtr, Int32, IntPtr, IntPtr)
at System.Windows.Forms.UnsafeNativeMethods.DispatchMessageW(MSG ByRef)
at System.Windows.Forms.Application+ComponentManager.System.Windows.Forms.UnsafeNativeMethods.IMsoComponentManager.FPushMessageLoop(IntPtr, Int32, Int32)
at System.Windows.Forms.Application+ThreadContext.RunMessageLoopInner(Int32, System.Windows.Forms.ApplicationContext)
at System.Windows.Forms.Application+ThreadContext.RunMessageLoop(Int32, System.Windows.Forms.ApplicationContext)
at System.Windows.Forms.Application.Run(System.Windows.Forms.Form)
at HotKey.Program.Main()
Event Xml:
<Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
<System>
<Provider Name=".NET Runtime" />
<EventID Qualifiers="0">1026</EventID>
<Level>2</Level>
<Task>0</Task>
<Keywords>0x80000000000000</Keywords>
<TimeCreated SystemTime="2015-07-21T13:14:20.000000000Z" />
<EventRecordID>1316</EventRecordID>
<Channel>Application</Channel>
<Computer>W230ST</Computer>
<Security />
</System>
<EventData>
<Data>Application: Hotkey.exe
Stack:
</Data>
</EventData>
</Event>
Joners
Yes, the version im using is the latest for the W230ST on the Clevo site. Ive even tried the W230SS software but its completely different and crashes immediately.
thisisevilevil
I usually only get that error if I disabled my WLAN card. If my WLAN card is disabled or driver not installed, my hotkey won't open and crashes with a similar error. That program is really made of plastic, lol.
EDIT: Yeah, check your WLAN and Bluetooth drivers. Make sure they are enabled and working.
Stack:
at HotKey.ControlCenter.radioButton6_CheckedChanged(S ystem.Object, System.EventArgs)
at System.Windows.Forms.RadioButton.OnCheckedChanged( System.EventArgs)
Pagey
I won't even be using it in W10, I won't even be losing much functionality as W10 has most of the controls at easy reach.
redxxvi
I'm currently using Hotkey 8.0101 (latest Win8 version from Clevo website) in Windows 10 on PCSpecialist P150EM.
I use it so I can turn off the backlit keyboard which would otherwise be on by default. I don't know if there is another way to disable it, short of unplugging a wire somewhere.
The software features work, but Hotkey seems to disappear occasionally (disappears from the taskbar, maybe broken by windows updates?) and I have to reinstall Hotkey.
The bluetooth LED light on the laptop stays lit whether bluetooth is on or off (or even with bluetooth device disabled), I hope maybe a future Hotkey version will address this.
