Hotkey, disable sleep
amoshi
Is there a way to disable the "sleep" binding in Hotkey (Fn+F4)? It's close to "volume down" and occasionally I hit it, so annoying.
Not that I'm aware of, that's hardcoded into hotkey, you'd have to change the code within the program. I could well be wrong here, best get someone else to confirm.
Pagey
You're lucky, there is a way:
1: Right click the power icon on the task bar and select "power options".
2: On the left of the window select "Choose what closing the lid does".
3: You should have settings for different criteria, just change the "When I press the sleep button" to whatever you wish.
4: Profit$$$
5: Enjoy.
mrducking
4: Profit$$$
5: Enjoy.
you forgot the step of ??? :D
amoshi
4: Profit$$$
5: Enjoy.
Ah, I thought it was Hotkey related. Thank you so much! :D
Rilufrod
Sleep mode wake up
I am also experiencing an issue with the sleep mode in that my laptop does not want to wake up again, I have had it less than a week and it should be behaving like a teenager yet!
