This is an usual request and I'm making it because I've never used homeplugs and so I know nothing about their reliability, availability, or performance, but I'm wondering whether they might be a solution to a problem.
The marina I'm in on Crete uses wifi to provide free Internet access. We have 6 hotspots spread around the marina so that most people can connect to one of them. The problem is that wifi is the worst system to use in a marina. When it's breezy and all these yacht masts are moving around we probably get all sorts of reflections and refractions that causes radio interference and TCP packets get dropped resulting in endless retransmissions etc.
In an ideal world we'd have an Ethernet cable at each electrical power box on the pontoons that we could plug into that would give us reliable Internet connectivity. The cost of installing Ethernet cabling in a marina with over 250 berths is out of the question (this is Greece remember).
However, we do have an electrical power point at every berth (standard three-phase 220v 50Hz AC just like the UK) so I'm wondering whether some type of Homeplug might be a potential solution? Bear in mind there are over 250 potential end points and the whole marina is served by two 24Mbps ADSL lines.
What do you think? Is this worth investigating further, or is it a non-starter?
