I am trying to build a high performance PC which will be used for scientific computing (analysis of large datasets, programming, office applications, web browsing, ...). The system will run Win7 and Ubuntu Linux via Oracle VirtualBox (with Win7 as the guest host).
My budget is 600 to 1200 pounds. Inside this price range I am looking for a system that offers good value for money.
My requirements are:
1. In general: High performance PC, can be used to analyse large datasets. I need a stable system that does not crash, so I am not interested in overclocking.
2. CPU: I am looking for a CPU which is on the higher end of the range, but I still want good value for money. I like the i7-4790k 4GHz because it ranks high on http://www.cpubenchmark.net/high_end_cpus.html. To me it looks like this CPU delivers the best value for money.
3. GPU: The PC will NOT be used for gaming. All I care about is that first, I can run 2 displays at up to 2560x1440 each, and second, that the GPU does not choke the performance of the system. Correct me if I'm wrong, but I believe I don't need a strong GPU because all I will do is display Office-like applications on 2 screens. The PC will NOT be used for sophisticated data visualisation, 3D, etc.
4. Cooling: I am looking for a quiet CPU cooler.
5. HD: Want to store my operating systems on SSD, but don't want to spend a lot on large capacity SSDs. 250 GB SSD for the OS together with a 1TB conventional HDD for applications and data seems a good compromise.
6. RAM: Need a decent RAM size to manipulate large data sets in RAM without HDD access. However, if I have a fast SSD then hard drive access might be less of an issue I suppose?
I am considering this spec:
FRACTAL DESIGN CORE 1000 BLACK CASE
Intel® Core™i7 Quad Core Processor i7-4790k (4.0GHz) 8MB Cache
ASUS® Z97M-PLUS: m-ATX, USB3.0, SATA 6.0, XFIRE
16GB KINGSTON HYPER-X BEAST DUAL-DDR3 2133MHz X.M.P (2 x 8GB)
1st Hard Disk
250GB Samsung 840 EVO SSD, SATA 6Gb/s (upto 540MB/sR | 520MB/sW)
CORSAIR 350W VS SERIES™ VS-350 POWER SUPPLY
INTEL STANDARD CPU COOLER
WIRELESS 802.11N 150Mbps PCI-E CARD (£6)
My questions are:
1. Does this spec generally make sense, given my requirements? Are there any inconsistencies or performance bottlenecks?
2. Is there any better value for money high performance CPU in the market than the i7-4790k?
3. Will the on-board GPU satisfy my requirements (2 screens @ 2560x1440 each, not choking the performance of the system)? Would buying a cheap GeForce card add any value here?
4. Any views on whether 16GB RAM are required or if 8GB are also fine? Will Kingston Dual-DDR3 vs Kingston Hyper-X Fury vs Kingston Hyper-X Beast make any difference in my spec?
5. I am undecided on the cooler, either the Intel standard CPU cooler or paying 39 pounds extra for the cheapest liquid CPU cooler (the CoolerMaster Seidon 120M). If I go for the CoolerMaster, will the system run more quietly and will it be completely without fans or are there still some other running fans in the case, even when going for liquid CPU cooling?
6. Will 350 watts be enough? I would only want to spend extra money on more watts if really required.
Thank you in advance for your suggestions.
1st Hard Disk
My questions are:
