Bandred
Since this is my first post, I'll start by saying 'Hi all'
I'm looking to replace my 5 year old PC and have been having a play with the 'builder'. I think I've got to a spec that will meet my needs, but would appreciate any comments or suggestions that others might have about it please.
Lets start with my objectives, before I add the build:
I used to build my own, but I'm older than Bruce Springsteen and have a chronic illness that severely limits my mobility, so a home build is not a good option for me anymore. I probably average about 12 hours a day using my PC. One main use is for running 3d modelling and rendering software, such as Modo and Vue. I also play games a lot, but these are generally RPG or strategy , such as Dragon Age or Anno 1404, so I don’t feel that I need a ‘top of the range’ graphics card. Essentially I’m looking for a build with good multithreading processing power, good OpenGL performance (for the modelling software) and good reliability and longevity.
With these points in mind and a budget target of around £1400, I’ve come up with the following:
COOLERMASTER HAF 922 MID TOWER GAMING CASE
Intel® Core™i7 Quad Core Processor i7-930 (2.80GHz) 4.8GTs/8MB Cache
ASUS® P6X58D-E: DDR3, USB 3.0, SATA 6.0GB/s, 3-Way SLI
12GB CORSAIR XMS3 TRI-DDR3 1600MHz (6 X 2GB)
768MB NVIDIA GEFORCE GTX460 GDDR5 PCI EXPRESS - DirectX® 11
INTERNAL 52 IN 1 CARD READER (READS XD, MS, CF, SD, etc)
CORSAIR 750W PSU (TX750) 80+ ULTRA QUIET
TITAN FENRIR EXTREME DIRECT TOUCH COPPER CPU COOLER
ONBOARD 10/100/1000 GIGABIT LAN PORT
Genuine Windows 7 Home Premium 64 Bit - inc DVD & Licence
Although I’ve specified the 768MB GTX 460, I’m planning on holding off ordering until a 1GB model is available to spec.
I’m not planning on over clocking right now, but I might get tempted eventually At the moment I’ve gone for what I believe are sensible cooling options for improved stability and longevity.
I did originally spec an 80GB SSD for a boot drive, but decided that probably had more to do with bragging rights that with being a real benefit for me so decided to opt for 12GB RAM instead. This might turn out to be an overkill, but 2GB RAM on Windows XP is currently the main frustration with my modelling software.
My main area of uncertainty is in the hard drive spec. I currently have about 1TB data, so need more than that on a new machine. I don’t know much about RAID configurations, so if anyone has thoughts on that I would be grateful, although I would be more concerned with better protection of data integrity rather than additional speed from it.
Thanks for any thoughts you might have,
Mike
Mike
