Help with spec
steventurnerpro
I am configuring my custom desktop on the site. I have basic understanding of computers and still finding selecting the appropriate items difficult.
What I require
dual screen
Mostly just surf the internet, watch youtube etc
gaming (Games like h1z1, csgo)
Multi tasking (1 screen gaming while other screen on internet or 1 screen watching video and one screen on internet)
Questions
1. From my description above is 8gb ram more than enough? This seems to be the standard amount nowadays. Is this too much for what I need or do I need to pay for more?
2. I am unsure about graphics cards. Is it simple enough to assume the higher gb the better the card? What size would be the minimum you would recommend?
3. I am clueless about motherboards. I do not have the slightest idea which would be the best option and the benefits of selecting a more expensive one or the cheapest one.
4. I am unsure on CPU. Again is it correct to assume i7 is better/newer than i5. Would I be better paying slightly less for a good i5 than an i7?
5. Processer cooling. I have no understanding on the benefit of this. Do I need pay for this or will the standard cooler do the job?
I would like an intel machine. Someone told me I should get kaby lake but I do not really understand what that is or the benefits.
I would like a balance between good value for money and a build that will last me a long time without having to upgrade.
Thanks in advance
Steven
A maximum budget will help to get an idea of what choices you have.
1) 8gb ram should be fine now but if you want to futureproof and can afford it you could choose 16gb ram instead.
2) depends on your budget. The VRAM is not a good indication of performance.
3) any will do the job
4) depends on your budget. An i7 is better and would futureproof your system for longer.
5) the standard intel cpu cooler is not very good
Rakk
The Awesome
Unfortunately its not as easy as that, its the model number that says how powerful it is, but again you can't just compare two numbers against each other (cos that'd be far too simple right :))
If you don't require any of the specific features of a particular motherboard then often the cheaper ones will suffice perfectly well
Yes the i7 is better than the i5, but dependent on budget it can often be better to go for the i5
Well if you let us know your budget I'm sure some suggestions can be made :)
Edit: I type too slow ...
steventurnerpro
This is what I came up with on the configurator. What can I do to decrease the cost without sacrificing the minimum requirements I need? (i have probably picked a much better machine than I require)
What is the difference in the 8gb ram options. Some are 2133mhz some are 2666mhz. What is the difference?
PCS SR-620 MID TOWER CASE
Intel® Core™i7 Quad Core Processor i7-7700 (3.6GHz) 8MB Cache
FREE Halo Wars 2 with select INTEL® CPUs!
ASUS® PRIME Z270-P: ATX, LG1151, USB 3.0, SATA 6GBs
4GB NVIDIA GEFORCE GTX 1050 Ti - DVI, HDMI, DP
1st Hard Disk
250GB WD Blue™ 2.5" SSD, SATA 6Gb/s (upto 540MB/sR | 500MB/sW)
500GB WD BLACK 3.5" WD5003AZEX, SATA 6 Gb/s, 64MB CACHE (7200rpm)
NOT REQUIRED
CORSAIR 350W VS SERIES™ VS-350 POWER SUPPLY
CoolerMaster Hyper 212X (120mm) Fan CPU Cooler
LED Lighting
50cm Blue LED Strip
Rakk
The Awesome
Can you see my response? It seems to have disappeared from view
That's cos you edited it :)
When you are new to the forums your posts will often get auto-moderated, meaning that no-one can see them til they've been approved by a mod, however this also applies to edits of previously approved posts - your post should be visible again now :)
steventurnerpro
My maximum budget is 1500 however this includes buying 2 monitors, mouse keyboard and desk. Ideally would like to spend as little as possible however I also do not want to handicap myself. If it is not possible t hen I can stretch it a bit
Perhaps something like:
InWIN GT1 BLACK GAMING CASE
Intel® Core™i7 Quad Core Processor i7-7700k (4.2GHz) 8MB Cache
Gigabyte Z270P-D3: ATX, LG1151, USB 3.0, SATA 6GBs
4GB AMD RADEON™ RX 480 - HDMI, 3 x DP - DX® 12 ()
FREE DOOM with AMD RX 480 Series GPUs!
1[SUP]st[/SUP] Hard Disk
M.2 SSD Drive
256GB SAMSUNG PM961 M.2, PCIe NVMe (up to 2800MB/R, 1100MB/W)
NOT REQUIRED
Price £1,238.00 including VAT and delivery
Unique URL to re-configure : https://www.pcspecialist.co.uk/saved-configurations/intel-z270-pc/hmR8tKUzXS/
You can get 23-24" IPS monitors for under £100 if you shop around, and Ikea desks for ~£100 or so.
So it should work out close enough to £1500.
