Hey guys just wondering if you could help me with this one, theres a few things i need to know so...
Does raid require 2 of the same HDD's to work properly? And is it worth getting 2x Intel SSD 510 series for the better performance or just raid with 1 or 2 normal HDD's? And is it even worth getting an SSD in the 1st place? Cheers.
Intel® Core™i7-2600 Quad Core (3.40GHz, 8MB Cache) + HD Graphics
ASUS® P8Z68-V: USB 3.0, SATA 6GBs, NVIDIA®SLI™, ATI®CrossFireX
3GB NVIDIA GEFORCE GTX 580 - 2 DVI, HDMI, DP - 3D Vision Ready
120GB INTEL® 510 SERIES SSD, SATA 6 Gb/s (upto 450MB/sR | 210MB/sW)
RAID
RAID 1 (MIRRORED VOLUME - 2 x same size & model HDD / SSD) (£9)
12x BLU-RAY ROM DRIVE, 16x DVD ±R/±RW (£45)
COOLERMASTER 750W GX SERIES™ -80 PLUS® BRONZE (£72) **SPECIAL***
RAID
