Help with new laptop Recoil III vs Vortex IX
Peterkse
Hi. Never had laptop always owned pc. Now after redecorating I lost my gaming room so my only option is laptop. I would like to connect my laptop sometimes to our Samsung UE40NU7120 4K TV. I can’t decide between recoil III or Vortex with G SYNC. I’m not big gamer. I play only Diablo 3, WOW.
My budget is somewhere around £1400 but can stretch to £1600
1st spec
Recoil Series: 17.3" Matte Full HD 144Hz 72% NTSC LED Widescreen (1920x1080)
Intel® Core™ i7 Six Core Processor 8750H (2.2GHz, 4.1GHz Turbo)
16GB Corsair 2666MHz SODIMM DDR4 (2 x 8GB)
NVIDIA® GeForce® RTX 2060 - 6.0GB GDDR6 Video RAM - DirectX® 12.1
500GB Samsung 860 EVO 2.5" SSD, SATA 6Gb/s (upto 550MB/sR | 520MB/sW)
256GB INTEL® 760p M.2 NVMe PCIe SSD (upto 3210MB/sR | 1315MB/sW)
Integrated 3 in 1 Card Reader (SD / SDHC / SDXC)
AC Adaptor
1 x 180W AC Adaptor
Recoil II Series 46WH Lithium Ion Battery
Bluetooth & Wireless
PER-KEY RGB BACKLIT UK QUIET MECHANICAL KEYBOARD
Notebook Mouse
INTEGRATED 1MP HD WEBCAM
Price: £1,416.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/recoil-iii-rtx-17/bPdSvNuANg/
2nd spec
Vortex Series: 15.6" Matte Full HD 144Hz LED Widescreen (1920x1080) + G-Sync
Intel® Core™ i7 Six Core Processor 9750H (2.6GHz, 4.5GHz Turbo)
1TB SEAGATE 7mm SERIAL ATA III 2.5" HARD DRIVE WITH 128MB CACHE (7,200rpm)
AC Adaptor
2 x 180W AC Adaptor
Vortex IX Series 6 Cell Lithium Ion Battery
1 x USB 3.1 PORT (Type C) + 2 x USB 3.0 PORTS + 1 x USB 2.0 PORT
MULTI COLOUR BACKLIT UK KEYBOARD
NO RECOVERY MEDIA REQUIRED
Notebook Mouse
Price: £1,647.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/vortexix-15/nNpyXzypdX/
Pokkai
Both of these models have HDMI out, so you'll be able to wire them directly into the telly. Just get the better paste on the Vortex if you go down that route.
It's a personal preference, but I'd always go for G-Sync, it eliminates screen tearing, on the laptop screen, not the TV, but it's down to your tolerance on that matter.
I know you're paying a premium for that, but it becomes more evident the older the machine gets, WoW will still bring a latest line rig to it's knees if you crank the FoV and Shadows to max, so you'll see some yards from it. If tearing doesn't bother you, you can save some cash and go for the Recoil, but there isn't much between them, the CPU jump from 8xxx to 9xxx isn't anything that will define the lifecycle of those PC's.
Enjoy the new machine.
I agree with Pokkai that it's personal preference.
The Recoil is 17.3" and cheaper. The Vortex has gsync.
What size screen do you want? If you don't care, then maybe the Vortex for Gsync. If you really want 17.3", the Recoil is a solid choice.
In terms of comparing the specs, bear in mind you have very different storage selected for each chassis.
The Recoil with the same storage as the Vortex above is £1550, so the Vortex is "only" £100 more, rather than £230 more. And, conversely, you could bring the Vortex's price down a lot by going with cheaper storage.
You don't need a 1TB SSD for these games. A 500gb SSD would be generously more than enough for those and Windows. You can have an HDD for mass storage.
And/or you could buy a cheaper model of SSD than the 970 Evo.
For the storage I'd suggest either
NOT REQUIRED
1TB ADATA SX6000 Pro PCIe M.2 2280 (2100 MB/R, 1500 MB/W)
Or
500GB WD Black™ SN750 M.2 NVMe SSD (up to 3470MB/s R | 2600MB/s W)
Depends how much storage you need. Either should give you more than enough.
Peterkse
Thank you both for your help. I’ll actually need to check different between 17.3 to 15.6”.
Is WD BLACK better than EVO 970 ? Or it’s just about price difference? I thing you right about how much storage I actually need. All my staff is on external hard drive anyway.
Do you think I should spend more and go for 2070 instead 2060? Will I benefit in any way with more expensive graphics card?
Laptop will be used only in our house so size, weight is not a issue.
In the beginning I was playing with idea of mini pc. Should I reconsider for this money?
After thinking for few minutes i’m leaning towards vortex because of g sync. Will see.
Thx you again. It’s actually really big help to hear others opinion. Much appreciated
They are fairly similar - and for gaming the performance will be the same. WD Black was a bit cheaper.
It's possible a 2070 will benefit you if you want to play WoW at 4k on the TV and push the settings higher. But it's not really useful for 1080p gaming, and you may feel it is too expensive.
If you don't need a laptop, then a PC is often a better choice, because you can upgrade the hardware in the PC. So in a few years if you want a new graphics card you can just replace the graphics card in the PC. Whereas with a laptop, you need to buy a new laptop for a new GPU.
The PCs that are called "mini" PCs are not always a great idea, because they have a lot of compromises versus regular PCs - and often are not very much smaller.
You can actually find 'normal' PCs with cases not much bigger than 'mini' PCs, but that have more features / upgrade options.
If you only need portability around the house, you might want to look into this:
Peterkse
Thx you. Just ordered Recoil III.
NVIDIA® GeForce® RTX 2070 - 8.0GB GDDR6 Video RAM - DirectX® 12.1
1TB WD Black™ SN750 M.2 NVMe SSD (up to 3470MB/s R | 3000MB/s W)
AC Adaptor
1 x 230W AC Adaptor
2 x 1 Metre UK Power Cable (Kettle Lead)
Notebook Mouse
Welcome Book
£1,721.00
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/recoil-III-rtx-17/xm5HPWSBQq/
