Help with new gaming pc
Hi everyone, I’m looking at getting a high-end gaming pc for around £2000 that I can also use for video and sound editing that will last 5 or so years.
I had thought about going with a Intel Core i7 Quad Core Processor i7-7740X (4.3GHz) 8MB Cache because I’ve read a lot of games still don’t take advantage of multiple cores. Also not sure whether to go with ASUS ROG STRIX X299-E instead of ASUS TUF X299 MARK 2 GAMING.
There was also another spec I was thinking of that had a ASUS X99-A II: ATX, USB 3.1, SATA 6 GB/s, with Intel Core i7 Six Core Processor i7-6850K (3.6GHz) 15MB Cache.
Any help with what would be best is much appreciated.
NZXT PHANTOM 410 WHITE GAMING CASE
Intel® Core™ i7 Six Core Processor i7-7800X (3.5GHz) 8.25MB Cache
ASUS TUF X299 MARK 2 GAMING: ATX, USB 3.1, SATA 6 GB/s, THERMAL ARMOR
16GB Corsair VENGEANCE DDR4 2133MHz (2 x 8GB)
8GB NVIDIA GEFORCE GTX 1080 - DVI, HDMI, 3x DP - GeForce GTX VR Ready!
1st Hard Disk
2TB SATA-III 3.5" HDD, 6GB/s, 7200RPM, 64MB CACHE
M.2 SSD Drive
256GB SAMSUNG PM961 M.2, PCIe NVMe (up to 2800MB/R, 1100MB/W)
NOT REQUIRED
CORSAIR 650W TXm SERIES™ MODULAR 80 PLUS® GOLD, ULTRA QUIET
PCS FrostFlow 100 Series High Performance CPU Cooler
WIRELESS 802.11 AC1300 867Mbps/5GHz, 400Mbps/2.4GHz PCI-E CARD
Monitor
IIYAMA GB2788HS-B2 27" 144Hz Gaming Monitor
Price £2,047.00 including VAT and delivery
Why not the i7-7700k instead? It would be cheaper and probably allow you to fit a gtx 1080 ti
What monitor are you pairing it with?
What kind of balance would you say between gaming and video editing? 50-50?
The balance between gaming and video editing would probably be 75-25 although I might just keep using my mac and final cut pro x for video editing . Mainly it will be used for gaming.
For a 1080p monitor a GTX 1080 ti is just a waste of cash.
Also, some people find that 1080p looks better at 24" rather than 27" - 24" often seems to be considered the sweet spot for 1080p.
ase
Overclocked CPU
Overclocked Intel® Core™i7-7700k Quad Core (4.20GHz @ up to 4.8GHz)
ASUS® ROG STRIX Z270E GAMING: LG1151, USB 3.1, SATA 6GB, Wi-Fi - RGB Ready!
1[SUP]st[/SUP] Hard Disk
M.2 SSD Drive
NOT REQUIRED
CoolerMaster MasterLiquid 240 High Performance Liquid Cooler
Monitor
Price £2,005.00 including VAT and delivery
Unique URL to re-configure : https://www.pcspecialist.co.uk/saved-configurations/intel-z270-overclocked/3Dp0SZJa2A/
Thanks for the advice. I’m thinking of going all out and getting a ViewSonic XG2703-GS 27-inch WQHD IPS Gaming Monitor with G-Sync (65Hz 1440p) with this build. Any thoughts?
Intel® Core™i7 Quad Core Processor i7-7700k (4.2GHz) 8MB Cache
ASUS® ROG MAXIMUS IX HERO: ATX, LGA1151, USB 3.1, SATA 6GBs - RGB Ready!
11GB NVIDIA GEFORCE GTX 1080 Ti - HDMI, 3x DP GeForce - GTX VR Ready!
1st Hard Disk
M.2 SSD Drive
500GB SAMSUNG 960 EVO M.2, PCIe NVMe (up to 3200MB/R, 1900MB/W)
NOT REQUIRED
Asus Xonar DGX 5.1-Channel Gaming Audio Card
WIRELESS 802.11 AC 867Mbps + BT4.0 + Intel Wi-Di PCI-E CARD
DVD Recovery Media
Speakers
LOGITECH S120 2.0 BLACK SPEAKER SYSTEM
Promotional Item
FREE Rainbow Six Siege with select SAMSUNG NVMe SSDs!
Price £2,171.00 including VAT and delivery
Why the Hero motherboard? What do you need that it offers but other ones do not? For instance one of the things it offers is support for liquid nitrogen CPU cooling. If you're not cooling your CPU with LN2...
The Z270E motherboard is already very expensive, has a pretty full set of features, and also includes 867mbps wifi and Bluetooth 4.1.
I'd suggest getting a pre-overclocked spec which you can configure here: https://www.pcspecialist.co.uk/computers/intel-z270-overclocked/ as it costs almost the same and gives you an overclock covered under PCS's warranty.
The 1080 ti would do well with 1440p high refresh.
I would drop this. The motherboard already has 7.1 audio and the onboard audio is fairly decent quality. I'd certainly recommend auditioning the onboard audio first. If you decide you want something better, a USB DAC may be worth looking into.
