So I am hoping for help, but I have a feeling it will be limited as I tried previously on here. The specs of my laptop are below, I bought it back in Feb 2013 (Vortex Series: 17.3"), and it is a fantastic laptop except for one problem, RADEON. Basically since the day I have had this laptop I have erratic bluescreens when loading games, all relating to hardware crashes with, you guessed it, the graphics drivers. I was told it was driver issues, and working in IT myself for 10-11yrs I kinda understood and expected that from AMD/Radeon. But the one blessing was that AMD were releasing newer drivers quite regularly and I was assured or at least I assured myself that the drivers would eventually come good and the blue screens would become less and less frequent.
Well here I am over a year later, and I been updating my RADEON drivers for the dual 7970 gfx cards in this laptop now up to 14.7 beta drivers I believe ( can I just add I remove all AMD drivers completely, boot into safe mode run a driver cleaner and then reboot before installing new ones). I have tried them all, I have even tried bespoke drivers from Guru3D but none have provided me with a stable base which would stop these damn blue screening errors. For example I loaded up Final Fantasy 14 several times the other day no problem, tried again yesterday and everytime it went to load up, BLUE SCREEN, eventually I had to load up Insurgency from Steam and then close that to then load up FF14, totally bizarre.
Now I have looked at the upgrade option that PC Specialist provides, but unfortunately my build will not allow any updates at all to the graphic card setup. I imagine its due to the motherboard but can't be sure for obvious reasons.
My question is, is there anything more I can do to fix this, is there any other alternative avenue for me to pursue, I don't mind spending money to switch my laptop from Radeon to Nvidia, but there isn't any facility to enable this, and I am not prepared to fork out another £1500+ for a new laptop just to fix this issue. I still have the Silver warranty, but because its a driver issue, or at least I think it is I am really not sure what PC Specialist can do either.
Does anyone else who potentially has gone through my problem have any ideas how to move forward. Its so demoralising loading up this beautiful laptop for gaming, when I have to play the BLUE SCREEN OF DEATH roulette wheel to see if it will let me load the game today...
Thanks in advance to anyone, and as I said earlier my specific laptop specs are below, thanks
You can find some history to my problem on this forum too at https://www.pcspecialist.co.uk/foru...change-a-gfx-card-on-previously-bought-laptop
Vortex Series: 17.3" Matte Full HD LED Widescreen (1920x1080)
Intel® Core™i7 Quad Core Mobile Processor i7-3630QM (2.40GHz) 6MB
8GB KINGSTON HYPER-X GENESIS 1600MHz SODIMM DDR3 (2 x 4GB)
2 x AMD® Radeon® HD 7970M - 2GB DDR5 Video RAM - DirectX® 11
1st Hard Disk
500GB WD SCORPIO BLACK WD5000BPKT, SATA 3 Gb/s, 16MB CACHE (7200 rpm)
Intel 5.1 Channel High Definition Audio + SPDIF/MIC/Headphone Jack
GIGABIT LAN & WIRELESS INTEL® N135 802.11N (150Mbps) + BLUETOOTH
4 x USB 3.0 PORTS + 1 x USB 2.0 PORT AS STANDARD
Vortex Elite 8 Cell Lithium Ion Battery (5,800 mAh/89.21WH)
1 x UK Power Lead & 300W AC Adaptor
INTEGRATED BACKLIT UK KEYBOARD WITH NUMBER PAD
Mouse
1st Hard Disk
Mouse
