Help with iCUE
Dzerx
Just had my new desktop arrive and having some issues with iCUE not picking up my extra ARGB fans for some reason. The fans are all lit-up a pink-brown colour, but I'm unable to coordinate or change colours as they're not showing in iCUE itself. The only things showing within iCUE are "ICUE LINK TITAN 360 RX, ICUE LINK RX RGB, ICUE LINK SYSTEM HUB, VENGEANCE RGB DDR5".
specs:
CORSAIR 3500X ARGB TEMPERED GLASS MID-TOWER (BLACK)
32GB Corsair VENGEANCE RGB DDR5 6000MHz CL36 (2 x 16GB)
16GB ZOTAC GEFORCE RTX 5080 SOLID OC - HDMI, 3 x DP
4TB CORSAIR MP600 PRO NH NVMe PCIe M.2 SSD (up to 7000 MB/R, 6500 MB/W)
CORSAIR 1200W HXi SERIES™ MODULAR 80 PLUS® PLATINUM V2
CORSAIR ICUE LINK TITAN 360 RX RGB HIGH PERFORMANCE CPU COOLER
4 x Corsair RS120 ARGB PWM Fan
ONBOARD 2.5Gbe LAN PORT
Microsoft® Edge
Miscellaneous
PCSpecialist 2023 Holo Sticker Sheet
Welcome Book
PCSpecialist Welcome Book
Logo Branding
PCSpecialist Logo
Packaging
PCS Corsair Carton Upright
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am5-pc/zxMQgUKJ4X/
I could be wrong, but I don't think the RS fans come with a controller, so they may be controlled by the motherboard software instead.
We normally recommend sticking to one type of fan / fan platform - so either all RS or all RX - to avoid this sort of mismatch.
Ignore that, as I've realised you've got RS fans with the case, so there should either be a controller included with the case already, or all 6 case fans are controlled via motherboard software (or 3rd party software like SignalRGB)...
Do you have more than one controller listed in iCUE?
Dzerx
Here's how ICUE looks.
Edit:
I've just noticed I had 'GCC' pre-installed which is the Gigabyte control centre. Soon as I clicked on that the other lights ARGB Fans lit-up a different colour meaning you might be right in that they're controlled via motherboard. Strange as I'd of thought they'd work with iCUE ngl.
The RS fans are the 'basic' fans, so are usually motherboard controlled, but at least they're daisy-chainable now, so don't need lots of splitters. The RX are the premium fans using the iCUE LINK ecosystem.
If the case came with RX fans it'd be £50 more expensive - but you could have ordered an RX fan kit which would have connected to iCUE with the cooler...but then the original 3 case fans would still have been RS fans.
I ordered a case without any fans, so I knew they'd all be matching - but that's the expensive way to do it :LOL:
Dzerx
yeah lesson learned. I've managed to change the RGB to something I like either way though so I appreciate the assist lol.
