I've posted before, but have a bigger budget now. I'm aiming for around £1500, but don't mind going to about £1600 if there's value in it.
I also care less about storage than I did before. I have lots of spare drives lying around, and will just buy a new one at some point in the future when I actually need it, so no need for a storage drive at the moment. I chose the case because it looked like a good choice for adding drives to.
Main use will be number crunching, programming, and playing around with pen-testing/capture-the-flag stuff. I'm not really a PC gamer so gaming isn't a priority, but ideally it would cope with older games and be able to stream TV shows on one monitor while working on another.
I'd like minimum 32GB RAM as I'll sometimes use Virtual Machines and other RAM-intensive programs.
My main monitor is LG 21:9 UltraWide 25UM57. I have a second VGA monitor which I'll probably replace with something better in the future, but I'm undecided on what it would be.
My main OS will be Linux, so no operating system required (although I'll probably dual boot with Windows eventually).
My attempt is below. I tried to follow the recommendations in the guide and don't really understand motherboards... The guide seems to recommend a minimum of 650W PSU, although the configurator warns me that I only need 450W?
Grateful for any help!
COOLERMASTER SILENCIO S600 QUIET MID TOWER CASE
CoolerMaster Hyper 212 (120mm) Fan CPU Cooler Black Edition
NO RECOVERY MEDIA REQUIRED
Price: £1,489.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am4-gen3-pc/p!hYxByQgR/
