have you used a USB data stick as the bootup drive?
I assume you can boot from a USB hard disk?
I have a usb hard disk with Macrium image files on it. Will I be able to make this drive bootable using the Macrium bootfile creator .
Can you use a usb3 hub with Macrium during restore of an image file?
I have never been into the bios on my computer?
I assume I will need to set the boot order in the bios?
thanks
Jonatahn
Yes, when it's booting it should give a quick display of the bios access keys (usually Del or F12 for Bios or F10 for boot menu)
