Help setting up open RGB
David689
On another thread I saw mention of openRGB so thought I would give it a go. But when installing/configuring it I am faced by a screen where I am not sure what figues to enter:
I bought my machine from PC specialist in Aug 2021. I changed the case from my original specification to the Lian Li Lancool 215 case so have cut and pasted below the specification of the final order.
If you need any more info then please let me know.
Any help greatfully received. Thank you.
Change to: LIAN LI LANCOOL 215 GAMING CASE
Processor (CPU)AMD Ryzen 9 5950X 16 Core CPU (3.4GHz-4.9GHz/72MB CACHE/AM4)
Memory (RAM)64GB Corsair VENGEANCE DDR4 3200MHz (4 x 16GB)
Graphics Card12GB NVIDIA GEFORCE RTX 3060 - HDMI, DP
1st M.2 SSD Drive1TB SAMSUNG 980 PRO M.2, PCIe NVMe (up to 7000MB/R, 5000MB/W)
Change to: 500GB SAMSUNG 980 PRO M.2, PCIe NVMe (up to 6900MB/R, 5000MB/W)
2nd M.2 SSD DriveNONE
Change to: 1TB SAMSUNG 980 PRO M.2, PCIe NVMe (up to 7000MB/R, 5000MB/W)
1st Storage DriveNOT REQUIRED
Change to: 2TB Samsung 870 QVO 2.5" SSD, SATA 6Gb/s (up to 560MB/sR | 530MB/sW)
2nd Storage DriveNOT REQUIRED
Change to: 512GB PCS 2.5" SSD, SATA 6 Gb (520MB/R, 450MB/W)
3rd Storage DriveNOT REQUIRED
Change to: 8TB SEAGATE BARRACUDA SATA-III 3.5" HDD, 6GB/s, 5400RPM, 256MB CACHE
DVD/BLU-RAY DriveNOT REQUIRED
Memory Card ReaderUSB 3.0 EXTERNAL SD/MICRO SD CARD READER
Processor CoolingCorsair H115i ELITE CAPELLIX RGB Hydro Series High Performance CPU Cooler
Wireless Network CardNOT REQUIRED
Build TimeStandard Build - Approximately 13 to 16 working days
B4zookaw
Yeah it's got a bit of a learning curve alright. One of its main audience profiles would be people running Linux who want to control RGB, and as everyone knows Linux users love self inflicted pain... 😂
My tip is to switch to Toggle LED View (button on bottom right) and it shows the layout of all the LEDS, makes it a bit easier to visual changes. And their Discord is very active and helpful.
