HELP!! PC isn't recognising my hard drives and optical drive?!
Sintect
Hello, in December 2011, I purchased my PC from PCS. Yesterday (December 25th) I turned on my PC with my new peripherals expecting to be able to use them. That was not the case, I get a message telling me that my PC can't boot as there is no disk to run and it redirects me to the BIOS. I am confident its not my hard drives because I have a 1TB HDD which wouldn't be detected or my 120GB SSD. Although when I plugged in my USB external hard drive, it would give me the option to boot from that. I also took out the SATA cables and put them back in and checked if there was any loose connections, this wasn't the case. When I went to install Win7 on my external, I also noticed that my optical drive wouldn't open. Thank you.
vanthus
Member Resting in Peace
As you're optical drive won't open,you have checked for dislodged connections and settings in bios appear OK,best give PCS a call tomorrow.
