Help on new PC build please
JosephMcC
Hi, so I’ve never really built a pc before but after researching many parts I’ve ended up with the below. Would this be great for high performance playing games and for future AAA games also. With all the new consoles coming out I thought I may as well make the switch to pc and then just upgrade or replace parts if need to. Any advice would honestly be so appreciated! Thank you guys :)
FRACTAL DEFINE S NANO GAMING CASE
Gigabyte B450 I AORUS PRO Wi-Fi AC (DDR4, USB 3.1, 6Gb/s)
8GB AMD RADEON™ RX 5700 - HDMI, DP - DX® 12
1TB PCS 2.5" SSD, SATA 6 Gb (520MB/R, 470MB/W)
NOT REQUIRED
CORSAIR 550W CV SERIES™ CV-550 POWER SUPPLY
STANDARD AMD CPU COOLER
LED Lighting
50cm Blue LED Strip
GIGABIT LAN PORT + Wi-Fi (Wi-Fi excluded on H310I-PLUS)
Monitor
AOC 21.5" E2270SWDN LED Monitor. 1920 x 1080, 5MS
ASUS Cerberus Keyboard & Mouse Bundle
Gaming Mouse Pad
PCS Gaming Mouse Mat - XXL
I would never recommend a mini-pc system. Are you willing to have a more traditional build? What is your budget?
Your usage is 1080p AAA gaming I guess? No other usage?
JosephMcC
hi Scott, yeah I’m quite open minded and my budget is flexible - yes for gaming purposes not other usage than maybe general use. Thanks for your help
also side note, what part of the Pc that I built was mini? That bit confused me
That's a mini form factor configuration, cramming a lot into a micro case.
For a normal config, you need this configurator:
When you say budget is flexible, what's your maximum? Obviously there's a ceiling where there's no point building above, we don't wanna spec up a 10k system if you're budget is 1250?
JosephMcC
Oh I understand, well if it’s just changing the case then isn’t that an easy fix?. My budget is £1250 :) thanks again
hillyhumbo
Hi, Joesph. Yes, I'd also suggest that you change to at least a "mid-tower" for your PC case. This would definitely help prevent the various components, such as the CPU, RAM, and Graphics card, from overheating and will also help make your PC more future-proof. A bigger PC case would also be helpful in your case, considering you are going for a stock AMD CPU cooler as opposed to liquid cooling.
I'd also suggest that you select a higher wattage for your power supply (PSU). A 550W power supply wouldn't be sufficient to run a 6-core CPU and an 8 GB AMD Radeon RX-5700. AMD officially recommends a minimum wattage of between 600W and 700W for their RX-5700 card. Feel free to go over to their official webpage for confirmation. :)
Having lower wattage (550W in your case) could lead to power throttling and system crashes/blue screen of death events. I'd suggest that you at least get 650W or 700W of power for your PC as it would definitely come in handy for the future too... in case you decide on upgrading your system components.
I hope this helped. Happy shopping!
Most monitors that you will want to purchase are out of stock. You want to look for the following specs:
1080p Resolution
24" Widescreen
144Hz Frequency
Freesync/ActiveSync/ G-Sync
Examples:
For the PC
CORSAIR 275R AIRFLOW TEMPERED GLASS GAMING CASE
NOT REQUIRED
Firefox™
Gaming Mouse Pad
Price: £1,088.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am4-gen3-pc/DSA!W84jvz/
JosephMcC
So I have finally reconfigured it to the below. Please let me know what you think as id like to make the purchase today :)
NOT REQUIRED
LED Lighting
50cm Blue LED Strip
Firefox™
Gaming Mouse Pad
Price: £1,000.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am4-gen3-pc/aHqfxCb4Yn/
It would be a shame to have a nice new system without a fast M2 drive to be honest but that's obviously up to youtself.
I would recommend the Silver warranty for £5. Saves you the return costs for any issues found.
JosephMcC
Thanks Scott, what fast m2 drive would you recommend? It is still under my budget and seems like an awesome gaming pc so I'm happy to look at a m2 drive. Also thanks again for all yours guys help, If it werent for ya'll i would have a mini that would overheat and im glad i came hear and sought advice instead of jumping straight into a purchase.
There was one on the spec I recommended ;)
JosephMcC
Does it make a difference if i have 1TB SEAGATE BARRACUDA SATA-III 3.5" HDD, 6GB/s, 7200RPM, 64MB CACHE in the M2 Drive or do you recommend that be in the M1 drive? Thanks Scott :)
I think you're getting mixed up.
The 1TB Seagate drive is just conventional storage. It's not a particularly fast drive and would only be used for holding bulk files that don't need speed.
The M2 drive I'm mentioning is the type of connection the drive has. In my recommendation it looks like this...
This is a PCS branded drive but you can see that its speed is VERY quick. It's the best value M2 drive, the next one up would be the Samsung EVO 970 but it's quite expensive.
JosephMcC
Okay I understand, I think i have my final draft - would you mind having a look over and letting me know your thoughts one final time? :) Can't thank you enough!
NOT REQUIRED
LED Lighting
50cm Blue LED Strip
Firefox™
Looks pretty good to me. The 650W PSU is much more power than you need but it does mean that if you choose to upgrade the GPU in the future you don't need to consider if you have enough power :)
