Hi there
My son (12 YO) is looking to move from Xbox up to a gaming PC, but tbh I am lost on the level of options that are out there. Have been using your super useful forums, but now not sure if I am getting more confused.
To start with he has nothing, so its a full set up that is needed. But I am confused as to whether take an easy option and by a pre-built (e.g. Alienware or Corsair One) or look into a custom build that you could provide. I;ve also historically always looked to Intel Chips, but some of the reading here is suggesting that an AMD might be better.
Any help will be gratefully received. Am looking to spend in the region of £1,500 for the PC (max £2k). At the moment, he's likely to only be playing fortnight, but I imagine that could change.
DaveBR3
DaveBR3
