HELP need to connect side panel fan
walkington
need to connect side panel fan to something but what?
NMEBowen
Master Poster
any of the cables that fit should be fine preferably the white one in the pc the other connector on the fan allows you to connect another item through the same point.
walkington
Problem #2!!!!!
My monitor has a VGA port only, my graphics card only has a dvi port so I can't connect them -.0
walkington
I don't think this adapter will work. It says it's to connect PC VGA to monitor DVI. You need the other way around don't you?
i thought that but if you look at the picture of the thing it's just an adapter with dvi one end and vga the other end. I think it works both ways, just connect my vga to the vga side of the adapter and then plug the dvi side of the adapter in
PokerFace
Banned
I'm not sure to be honest. You could ring PCS in the morning and point them to the links in this thread. See what they advise would be best, unless someone else can put their tuppence worth in before you speak with them.
Good luck, let me know what worked for you.
