Hey all,
So i have a Def 3 with gtx 1060 17'' laptop from PCS.
When on the battery i will get random screen blackout's/refreshes. To sum it basically ill be doing my own thing the screen will go dark like it's switched off and then turn it's self back on after a second or two. Can happen multiple times in a row or apart but it happens often.
I've spoke to PCS and their suggested fix was the latest intel gpu drivers for the on-board which I've done and it hasn't fixed it. Any suggestions other than a loose screen?
Second issue, I've recently starting getting crashes, the laptop is about a month hold.
for reference i have my OS on a ssd or atleast what should be an 240gb ssd. and non system essitianal on my wd black 750gb 7200 rpm hdd.
The first major crash was a grinding noise which i would typically associate with a hdd failing, it crashed the entire system. Which is interesting as the OS isn't stored on the hdd at all. To my own knowledge ssd don't contain mechanical parts and therefore shouldn't fail in this manner.
it's worth noting that this wasn't a temperature crash as the laptop wasn't hot at all.
the second version of this crash is a complete freeze and the laptop is unresponsive to commands par the usual hold the power button down etc.
i have 16gb of ram, I7 6700hq cpu. i cannot for the life of me figure out the cause of the freezes nor the scratching/mechanical disc failing noise.
