Help me choose - Intel vs AMD
amig
Attempting a custom build after a decade of being out of the loop - please help me choose! I'm quite familiar with the Intel processors but not AMD Ryzen. I'm looking for a mid-range build for office work, occasional gaming but something that can be usable for many years.
I haven't picked out a monitor yet but will not go for anything bigger than a 24" (suggestions welcome)
Intel - £1100AMD - £1279
CasePCS GENESIS G1B CASE + SD CARD READERPCS GENESIS G1B CASE + SD CARD READER
Processor (CPU)Intel® Core™ i7 Eight Core Processor i7-9700 (3.0GHz) 12MB CacheAMD Ryzen 9 3900 12 Core CPU (3.1GHz-4.3GHz/70MB CACHE/AM4)
MotherboardASUS® TUF H310M-PLUS GAMING R2.0: Micro-ATX, DDR4, LGA1151, USB 3.1, SATA 6GBsASUS® TUF X470-PLUS GAMING (DDR4, 6Gb/s, CrossFireX) - RGB Ready!
Memory (RAM)32GB Corsair VENGEANCE DDR4 2400MHz (2 x 16GB)32GB Corsair VENGEANCE DDR4 2400MHz (2 x 16GB)
Graphics Card6GB NVIDIA GEFORCE GTX 1660 - HDMI, DP - GeForce GTX VR Ready!6GB NVIDIA GEFORCE GTX 1660 - HDMI, DP - GeForce GTX VR Ready!
1st Storage Drive1TB Samsung 860 QVO 2.5" SSD, SATA 6Gb/s (upto 550MB/sR | 520MB/sW)1TB Samsung 860 QVO 2.5" SSD, SATA 6Gb/s (upto 550MB/sR | 520MB/sW)
DVD/BLU-RAY Drive24x DUAL LAYER DVD WRITER ±R/±RW/RAM24x DUAL LAYER DVD WRITER ±R/±RW/RAM
Memory Card ReaderUSB 3.0 EXTERNAL SD/MICRO SD CARD READER
Power SupplyCORSAIR 450W VS SERIES™ VS-450 POWER SUPPLYCORSAIR 450W VS SERIES™ VS-450 POWER SUPPLY
Power Cable1 x 1 Metre UK Power Cable (Kettle Lead)1 x 1 Metre UK Power Cable (Kettle Lead)
Processor CoolingCorsair H60 Hydro Cooler w/ PCS Ultra Quiet FansCorsair H60 2018 Hydro Series High Performance CPU Cooler
Thermal PasteSTANDARD THERMAL PASTE FOR SUFFICIENT COOLINGSTANDARD THERMAL PASTE FOR SUFFICIENT COOLING
Sound CardONBOARD 6 CHANNEL (5.1) HIGH DEF AUDIO (AS STANDARD)ONBOARD 6 CHANNEL (5.1) HIGH DEF AUDIO (AS STANDARD)
Wireless/Wired NetworkingWIRELESS INTEL® Wi-Fi 6 AX200 2,400Mbps/5GHz, 300Mbps/2.4GHz PCI-E CARD + BT 5.0WIRELESS INTEL® Wi-Fi 6 AX200 2,400Mbps/5GHz, 300Mbps/2.4GHz PCI-E CARD + BT 5.0
USB/Thunderbolt OptionsMIN. 2 x USB 3.0 & 2 x USB 2.0 PORTS @ BACK PANEL + MIN. 2 FRONT PORTSMIN. 2 x USB 3.0 & 2 x USB 2.0 PORTS @ BACK PANEL + MIN. 2 FRONT PORTS
Operating SystemWindows 10 Home 64 Bit - inc. Single Licence [KUK-00001]Windows 10 Home 64 Bit - inc. Single Licence
Operating System LanguageUnited Kingdom - English LanguageUnited Kingdom - English Language
Windows Recovery MediaWindows 10 Multi-Language Recovery Image - Unlimited Downloads from Online AccountWindows 10 Multi-Language Recovery Image - Unlimited Downloads from Online Account
Office SoftwareFREE 30 Day Trial of Microsoft® Office® 365 (Operating System Required)FREE 30 Day Trial of Microsoft® Office® 365 (Operating System Required)
Anti-VirusNO ANTI-VIRUS SOFTWARENO ANTI-VIRUS SOFTWARE
BrowserMicrosoft® Edge (Windows 10 Only)Microsoft® Edge (Windows 10 Only)
Warranty3 Year Silver Warranty (1 Year Collect & Return, 1 Year Parts, 3 Year Labour)3 Year Silver Warranty (1 Year Collect & Return, 1 Year Parts, 3 Year Labour)
DeliverySTANDARD INSURED DELIVERY TO UK MAINLAND (MON-FRI)STANDARD INSURED DELIVERY TO UK MAINLAND (MON-FRI)
Build TimeStandard Build - Approximately 12 to 14 working daysStandard Build - Approximately 12 to 14 working days
Promotional ItemChoose from 6 Incredible Ubisoft Titles FREE with select SAMSUNG SSDs!PCSpecialist Welcome Book - United Kingdom & Republic of Ireland
Price (inc VAT)
£1,110.00​
£1,279.00​
Reconfigurehttps://www.pcspecialist.co.uk/saved-configurations/intel-home-office-pc-II/PeJFT3g8X4/https://www.pcspecialist.co.uk/saved-configurations/amd-am4-gen3-pc/Xdv8CJzBh4/
steaky360
I think the general consensus is that AMD are smashing Intel at the moment with the latest generation of processors.
AMD vs Intel is the wrong question tbh.
The question is what fits best for your budget and uses.
I don't think either of those specs is a good fit?
Why are you buying an R9 for office work and light gaming? That's not futureproof for those, it's just overkill to the point of being a waste as you'll never reap the benefits. Same with 32gb RAM.
Why the X470 mobo?
Get a better case, it will help with airflow and cooling
The 860 QVo isn't worth it. A cheap M.2 SSD will generally be faster and can also be cheaper. And most of those games you can get cheap on sale too.
Instead of either spec:
CORSAIR CARBIDE SERIES™ 275Q QUIET CASE
Get 3 Months of XBOX Game Pass for PC w/ select AMD Ryzen CPUs
NOT REQUIRED
NOT REQUIRED
External DVD/BLU-RAY Drive
Price: £1,030.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am4-gen3-pc/peskUqPQKJ/
As for monitors, something 1080p 144hz maybe:
e.g. AOC G2590PX
amig
@Oussebon Thanks for your detailed reply. I'm not up to date on the specifics of each item so just picked what looked appropriate and close to my budget of around £1300. I should've mentioned but I also intend to do coding/development on this PC which was the reason for choosing 32GB (I mainly use Visual Studio) Also, given that extra detail, would you still recommend Ryzen 5? Rest of your build looks perfect for my needs.
VenatoS
Intel for Gaming if you have a big budget.
AMD for Gaming if you are on a limited budget.
AMD for everything else atm.
Inlte is not necessarily a smart buy if you have a "big budget"... you might have a big budget but be playing at 4k. If buying an i9 9900K means you're stuck with an RTX 2080 Super instead of a 2080 ti, an R5 or R7 would still be the sensible buy. Even if it didn't, you'd see about 0 performance difference between them at 4k...
Move on,
The R5 3600 should be great in visual studio. If you're confident you'll need 32gb RAM, then by all means :)
amig
Hi @Oussebon , nearly there with the purchase :). When I try to proceed with your config I get the following message :
You have selected a 550W power supply, but based on our calculations you actually only need a 350W power supply. We have calculated your specification to require around of 317W power including a 20% allowance. Although it is not a mandatory requirement to select a lower wattage power supply, doing so will save you money and the last thing we'd like to do is over charge you!
Wondering if you selected the Corsair 550W because it's supposedly quieter ? Or some other reason? Thanks
The reason the 550W has been chosen is because it's the Txm range which is vastly superior to the VS range, it's overpowered but leaves headroom for future upgrades. It won't do any damage by being overpowered.
VenatoS
PSU's work most efficiently on 50-60% usage.
So a higher Wattage PSU Isn't a bad idea at all & as mentioned above leaves room for upgrades if needed.
As above, better quality, more efficient, modular. And 550W as that gives you decent freedom for upgrades.
It's true that PSUs tend to be more efficient at around 50% load, though in reality with something like the TXm that's the difference is about 2% which is a few Watts. That said, while gaming isn't the most environmentally friendly passtime, every little helps I guess :)
